Used cam & lifters,Comp Cams hydraulic flat tappet - 460 Ford Forum
post #1 of 1 (permalink) Old 10-28-2007, 06:49 PM Thread Starter
Y2K
$100 for a used but nice Comp Cams Hydraulic flat tappet performance cam & lifters with a double true roller timing set.
I'm upgrading the whole motor so have no used for it anymore.
Fits Ford 429 or 460 engines non computer controlled '68-'94.
Call 360-907-8759
Summit racing sells the cam alone for $126.95 part# CCA-34-227-4
Brand: COMP Cams
Product Line: COMP Cams High Energy Camshafts
Part Type: Camshafts
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,500-5,500
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 218
Duration at 050 inch Lift: 218 int./218 exh.
Advertised Intake Duration: 268
Advertised Exhaust Duration: 268
Advertised Duration: 268 int./268 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.494 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.494 in.
Valve Lift with Factory Rocker Arm Ratio: 0.494 int./0.494 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: No
Grind Number: FF 268H-10
Y2K is offline
