Brand new COMP CAMS - Cam & Lifters $115 - 460 Ford Forum
post #1 of 5 (permalink) Old 11-08-2007, 12:27 PM Thread Starter
I bought these a while ago from Summit and my builder put a roller cam in instead. They are brand new and never run. I just don't have the original boxes because they were installed and then taken back out before it was ever turned over. They are in perfect new condition. I paid full price for it. I'd take $115 for the set.
1) Magnum Hydraulic Flat Tappet Camshaft & Lifters $206 at Summmit
http://store.summitracing.com/partde...CL34%2D337%2D4
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 3,000-6,800
Intake Duration at 050 inch Lift: 253
Exhaust Duration at 050 inch Lift: 253
Duration at 050 inch Lift: 253 int./253 exh.
Advertised Intake Duration: 305
Advertised Exhaust Duration: 305
Advertised Duration: 305 int./305 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.585 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.585 in.
Valve Lift with Factory Rocker Arm Ratio: 0.585 int./0.585 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Grind Number: 305H
Lifters Included: Yes
Lifter Style: Hydraulic flat tappet
GT500KR_Vert is offline
post #2 of 5 (permalink) Old 11-09-2007, 05:09 PM
Send a message via Yahoo to fastbigblockford
you still got this stuff?? if so i would be very interested.
thanks
Later
Dan
fastbigblockford is offline
post #3 of 5 (permalink) Old 11-30-2007, 07:29 PM Thread Starter
bump
post #4 of 5 (permalink) Old 12-01-2007, 04:58 PM
PM sent
93TurboStang is offline
post #5 of 5 (permalink) Old 12-07-2007, 09:18 AM Thread Starter
bump
