32 ford sand \ mud altered - 460 Ford Forum
post #1 of 1 (permalink) Old 11-22-2007, 10:54 AM Thread Starter
31altered's Avatar
Send a message via AIM to 31altered
up for auction is a 1932 ford 4x4 sand altered with a new 557 blown injected bbf the 557 ci is all new with a sonny bryant billet crank , grp alum rods diamond pistons , laniti billet roller cam, motor has the best of everything alum . fully ported blue thunder heads all new hampton 871 racer stripped alcohol polished blower with a enderle birdcatcher hat injection , the chassis is all chrome moly funny car tube chassis with 4 linked front and rear , the rear is a fabucated ford 9 inch with 6.00 gear strange spool and strange 3rd member all new with wilwood disc brakes and moser 35 spline axles , the front axle is a open 3.50 all fresh with wilwood disc brakes, the transfer case is a open chain drive wuith changable gear to change front gear ratio to match the rear extra gear so if you want to go up or down on rear its easy to change front ratio, the tranmission is all new C-6 with a art carr valve body with brake and a 5000 stall all roller trans , all msd ignition , auto lite gauges, halon system , the tires are all new with 33 X 17 x15 super scoops on 20 wide rims in rear and new desert trac fronts tires much much more,,,,,,,,,,,,,, CALL OR EMAIL FOR MORE INFO [email protected] or 517/468/2454 or 517/285/4751 thanks for looking sold as is possible parital tr,ade email with info I HAD DECALS ADD TO THE SIDES AND BACK THE SAY LETHAL INJECTION $25500.00
31altered is offline
