Rolling Chassis Fox Body Mustang w powerglide $5000 - 460 Ford Forum
post #1 of 12 (permalink) Old 06-20-2008, 03:37 PM Thread Starter
Hi... Im selling my fox body mustang and I will get some pics this weekend. This car is a good looking car that drives straight and hooks good. I had a mild windsor in the car that would run consistent mid to high fives in the 1/8 mile with 1.29 sixty foot times on a small shot of gas. It is a stock type suspension car.
List of mods-
-Front end has qa1 tubular k member (all front end parts are new), tubular a arms, coil over strut conversion kit with lakewood 90/10 shocks. New brake calipers and brake hoses, (has line lock but not hooked up), new steering rack and tie rod ends.
-Rearend is a 9 inch with a Strang aluminum 3rd member, spool, with 4:10 gears, Mosier 35 spline axles, Wilwood Disc brakes, South side lower control arms, lakewood 50/50 shocks, passenger side air bag (but not needed) this car is not tubbed out.
-Has rear subframe connectors with a ten point cage, 28x10.5 mickey thompson et slicks with only 8 passes with tubes on ten inch drag lites, front has mickey thompson et front runners with tubes on draglites.
- 6" lift off extended cowl hood, two racing seats, lexan windows in the door and the rear hatch, the car also has a drag wing, safety shut off swith mounted in the back, rear mounted battery, Aluminum Griffin radiator with dual electric cooling fans, the car is dark blue in color and looks pretty good. The front end parts are brand new and have never been used. Front springs are set up for a big block.
I also will throw in a freshly built powerglide that has a deep pan, transbrake, good bands, 1.76 planetary, bte hardened input shaft and a sfi bellhousing that adapts the powerglied to a small block ford, also comes with the hardened driveshaft and yokes. I will even throw in a mallory hi-fire ignition box to. The car pretty much has everything but the fuel system and ignition wiring.
I will be getting sum pics this weekend, the car has a clear title, I am asking $5000 for the car. I would prefer local pickup, if you would like to know more please let me know, you can call me on my cell phone at 229-848-3415. The car is located in Tifton, Georgia........ Thanks, Greg
speedtech460 is offline
post #2 of 12 (permalink) Old 06-20-2008, 03:55 PM
Wow .. mid 5's with a mild smallblock. what does the car weigh ??
" A - Head Groupie"
blastertech70 is offline
post #3 of 12 (permalink) Old 06-20-2008, 04:45 PM
I may be interested, so ill start the line! Cant wait for pics!! -Later
93TurboStang is offline
post #4 of 12 (permalink) Old 06-21-2008, 12:11 PM Thread Starter
Yea it had some decent parts but it was only 360 inches with victor jr heads and one stage of nitrous. I never actually weighed the car but my guesstimation would be 2900 to 3000lbs with me in it. I am going 2 get some pics this afternoon.....thanks, Greg
post #5 of 12 (permalink) Old 06-21-2008, 12:13 PM Thread Starter
I was planning to put a big block in this chassis so whatever engine combo is used in the chassis, the spring on the front are for a big block now. thanks
post #6 of 12 (permalink) Old 06-21-2008, 12:31 PM
BBFmavrick's Avatar
Rick Brown
Member of a BAND OF BROTHERS
Pro Motion Machining
Bronx Corner Automotive
BBFmavrick is offline
post #7 of 12 (permalink) Old 06-21-2008, 04:51 PM Thread Starter
forgot to add the car will also have upr caster camber plates on the front and the Flaming River steering shaft and knuckle kit. I just took a pic of the car with the front end being completed, pic is not a good one though, front end will be completely finished tomorrow, car is also gonna get a wash job as it has dust from sitting in the shop. Thanks
post #8 of 12 (permalink) Old 06-21-2008, 05:41 PM Thread Starter
http://s281.photobucket.com/albums/kk207/ghilt17/
Here are a few quick photo's....I will have more and better photos tommorrow, the front will be complete also. Thanks, Greg
post #9 of 12 (permalink) Old 06-22-2008, 02:08 PM Thread Starter
Any offers????
post #10 of 12 (permalink) Old 06-22-2008, 04:16 PM
You need better pics. Try daytime pics. Include engine bay, interior, rear end etc. Good luck
"RUN HARD OR RUN HOME"
545lx is offline
post #11 of 12 (permalink) Old 06-22-2008, 05:39 PM Thread Starter
Ok, Got it back together and have more pictures. Maybe this will help.....Thanks, Greg
post #12 of 12 (permalink) Old 06-23-2008, 09:28 AM Thread Starter
Rolling Chassis Fox Body Mustang w powerglide Reduced Price
$4500
