Ford Motorsport M-6200-A75 Rods - 460 Ford Forum
post #1 of 5 (permalink) Old 07-28-2008, 08:02 PM Thread Starter
Paul Kane's Avatar
Quoted: 45 Post(s)
RODS ARE SOLD
Brand new and in the factory packaging (this box opened for pictures only and you will receive an unopened factory box
of brand new rods). The A75 rods are the late model "double dimple" rods and are essentially an updated version of the
D6VE truck rods and/or D0OE Cobra jet rods. These rods have more material around both the big end and the pin end
than the CJ/truck rod, thus making them stronger in that area (less likely to flex at the big end and grab a journal, etc.).
They are similar to what came in the early 514 crate motors, but without the 0.990" pin bushing.
  • Standard length OEM 6.605"
  • Standard dimension OEM 1.040" press fit pin bore
  • Standard dimension 2.500" OEM crankshaft rod journals bearing application
Completely brand new and loaded with rod bolts, ready to use, etc. You can't have a machine shop rebuild your
30-year old rods for our asking price of these brand spanking new rods. If I had to build an engine for a competition
that required an OEM stock Ford rod, this is the rod I would use.
We are releasing just one set at this time. $129 + $10 flat shipping anywhere in the continenal United States
(this is a break on shipping to just about everywhere in the U.S.). For shipping to areas other then the continental U.S.,
please inquire for a quote.
RODS ARE SOLD
Call, email, or PM if interested.
Paul
310-435-1900
High Flow Dynamics
Paul Kane is offline
post #2 of 5 (permalink) Old 07-28-2008, 08:31 PM
so i'm sure this question will annoy someone but i gotta ask. what would the rpm range be on these rods in a warmed over street application? and do they need any other machining besides balancing in order to use them.
thx terry
tubais is offline
post #3 of 5 (permalink) Old 07-28-2008, 08:52 PM Thread Starter
Paul Kane's Avatar
Quoted: 45 Post(s)
thx terry
Terry,
These are brand spanking new rods, the latest revision, new rod bolts etc. They are as new and as updated as the OEM rods get. The cost of reconditioning older rods with new bolts and machining will far exceed the price asked for these new ones, and the reconditioned rods will still be a used set of rods. So, not only are these a better value price-wise than reconditioned rods, but the are more likley to hold up in a warmed over street engine than the used rods because these have not yet been stressed in an engine. Also, you will know their entire history. They will need no more machining than any other typical new part, meaning it depends on what you are building but more than likely can be used as-is for their intended application.
In regards to rpm, the general consensus as of late seems to be that reconditioned OEM passenger car rods can support perhaps 550-600 hp, but rpm comes into play here and most people don't think it's a good idea to take them past 6000 rpm. But these rods are brand new and have more material around the big end and pin end than the earlier rods. The beam section is the same.
What's funny is that before there were aftermarket steel rod options for the 460, we only had the stock rods and back in those days many people regularly ran the TRW L2443 dome tops and spun the engine to 7K. Also, Jon Kaase currently has a 521 with these very rods in it (bushed to 0.990" pin) and that engine has supported over 700hp with them. My jet boat ran older passenger car rods with TRW L2443's at 5000 rpm sustained for years and years, no trouble. All that being said, I am not suggesting that you use these anecdotes for establishing oem pass car rod capabilities, but the points are noteworthy nonetheless.
If the used/reconditioned OEM rods still hold up as noted above (550hp/6000 rpm, generally), then what we are offering--a brand new set of rods, and an updated version of them--ought to hold up at least as well, if not better, than an old set of reconditioned CJ rods. As stated in the original post, if I had to build an engine for a competition that required an OEM stock Ford rod, this is the rod I would use. They are the strongest of the OEM 460 rods.
Paul
p.s.: I can post pics of the differences between these rods and all the earlier OEM rods if anyone wants. Much more material in these rods.
High Flow Dynamics
post #4 of 5 (permalink) Old 07-28-2008, 10:51 PM
thank for your very informative post.
terry
tubais is offline
post #5 of 5 (permalink) Old 07-29-2008, 05:13 PM Thread Starter
Paul Kane's Avatar
Quoted: 45 Post(s)
RODS ARE SOLD
Thanks everyone, and thanks Chilly. 8)
Paul
High Flow Dynamics
Closed Thread
