Need 9" parts - 460 Ford Forum
post #1 of 11 (permalink) Old 09-14-2008, 05:11 PM Thread Starter
BBFmavrick's Avatar
Need 9" parts
I just purchased a 53 1/2" 9" housing for my 68 FB that I'm redoing.BUT, It needs backing plates, and a set of stock 28 spline axles. What do you have :?: Rick
Rick Brown
Member of a BAND OF BROTHERS
Pro Motion Machining
Bronx Corner Automotive
BBFmavrick is offline
post #2 of 11 (permalink) Old 09-15-2008, 07:09 PM Thread Starter
BBFmavrick's Avatar
Hey Guy's :?: I'm not real familiar w/what will interchange, But I was wondering if the axles and backing plates from the 8" that is in the car now will work on the 9" housing :?:
Rick Brown
post #3 of 11 (permalink) Old 09-15-2008, 07:50 PM
I have 2 axles and 2 stock backing plates, 28 spline and dirty from sitting around....69 stang 9 inch, might be what your looking for, will get rid of cheap...I'm in Syracuse NY
nos42 is offline
post #4 of 11 (permalink) Old 09-15-2008, 09:03 PM Thread Starter
BBFmavrick's Avatar
Post me a price Thanks Rick
Rick Brown
post #5 of 11 (permalink) Old 09-15-2008, 09:11 PM
50 bucks plus shipping, hows that sound?
nos42 is offline
post #6 of 11 (permalink) Old 09-15-2008, 09:32 PM Thread Starter
BBFmavrick's Avatar
I'll get back w/you in a couple of days, I will take them if my 8" stuff don't fit. Thanks Rick
Rick Brown
post #7 of 11 (permalink) Old 09-15-2008, 09:40 PM
cool!
nos42 is offline
post #8 of 11 (permalink) Old 09-15-2008, 10:45 PM
hey NOS42 got pic's of those parts. not spinning any ski roller wheels
2slow is offline
post #9 of 11 (permalink) Old 09-17-2008, 04:54 PM
If your housings are the same length, the 8" stuff should work fine in the 9" housing
8)
truebluecobra is offline
post #10 of 11 (permalink) Old 09-17-2008, 06:56 PM
David Cole's Avatar
The axles length will worj if the housing is the small length or within 1/2" wider.
The key for the backing plates (and matching brakes) along with the axles bearings is: What housing ends does the new rear have?
The 8" rear will have "small ford" housing ends and bearings. Some 9" rear ends also use this housing end. If the new 9" has "big ford" or "new style big ford" aka "torino style" you will need new backing plates, brakes and axle bearings. Take a look at this chart to see which one you have:
http://www.steeltechsolutions.com/REAR_AXLE_ID.html
Also note that the small ford housing ends uses 3/8" bolts to attach the backing plates. Big ford housing ends use 1/2" bolts.
86 T-Bird chassis car
Struts, ladders and W's
Alky injected BBF
David Cole is offline
post #11 of 11 (permalink) Old 09-20-2008, 10:30 AM Thread Starter
BBFmavrick's Avatar
David, Thank You Very Much for posting that chart. I have the late Torino/fairlane housing w/3.150 bearings. :?: Did the Torino/Fairlane's shock, mount to the housing instead of the ubolt spring pad like the Mustang :?: My 8" Mustang stuff won't come close to fitting.
Rick Brown
