Flow Kooler Water Pump $55.00 - 460 Ford Forum
post #1 of 2 (permalink) Old 11-12-2008, 09:04 PM Thread Starter
70429scj's Avatar
NIB Part # 1651 Water Pump. How about 55.00 plus shipping.
Steve
Flow Kooler 1651 $99.88
Brand: Flow Kooler
Product Line: Flow Kooler Mechanical Water Pumps
Part Type: Water Pumps, Mechanical
Part Number: BRA-1651
Pump Flow: High-volume
Pump Material: Iron
Pump Finish: Natural
Rotation: Clockwise
Pilot Diameter (in): 0.625 in.
Water Pump Inlet Diameter (in): 2.062 in.
Quantity: Sold individually.
Water Pump, Mechanical, High-Volume, Iron, Natural, Ford, 429, Each
Check to make sure this part fits your application Get 30 percent extra coolant flow.
Flow Kooler water pumps solve low-speed heating problems by doubling the water flow rate at low rpm and idle. At 3,500 rpm, the flow rate returns to normal, to prevent too much water flow at high speeds. These pumps also last longer than a stock replacement. They use a specially designed steel plate on the impeller that traps water, eliminates cavitation, increases flow, and reduces engine temperatures.
70429scj is offline
post #2 of 2 (permalink) Old 11-13-2008, 07:37 PM Thread Starter
70429scj's Avatar
ttt
ttt
70429scj is offline
