4150 Victor, 460 shortblock,ACC Outlaw 9.5" C-6 Convertor, 5" Autometer tach, 350 warrior quad - 460 Ford Forum
post #1 of 14 (permalink) Old 02-10-2009, 03:27 PM Thread Starter
Victor Intake 4150 $200
460 D1 block, Std. bore, cleaned, honed, sonic checked, new cam bearings installed, Crank is standard and just polished, rods and pistons cleaned and checked for size, new main bearings, and new pre 1975 timing chain set. Needs rod bearings, rings, and assembled. $450 takes all of it.
Big pilot, C-6 Convertor, used about 200 miles, too big of stall for my set up. This convertor will go about 3500 on the foot brake. $525 new, sell for $250 or trade for a 2800-3200 C-6 stall.
Below is a desription from their ad---
"This ACC Performance Wild Boar level 1 "Outlaw" torque converter works great in performance street / strip engines with a stall speed of approximately 3500 to 4200 RPM depending on application. Converter is approx. 9.5" in diameter.
Equipped with anti-balloon plates, the Outlaw series converters are built to withstand heavy nitrous and trans brake applications where extreme loads will be put on the drivetrain. HP and torque capabilities of ACC Performance torque converters are 800+
The automotive industry now has a new torque converter leader. ACC has emerged as a out-right leader in this industry and hereís why:
Welded not Furnace Brazed. Contrary to popular belief, furnace brazing is not the best way to adhere torque converter components to together. Just like a Teflon coated pan, after some time the furnace brazing will erode away and ruin the stators and all other rotating parts in your transmission. All of ACC torque converters are welded at the seams, not brazed, to eliminate the erosion after time.
Industrial Bearings - No Light Duty Needle Bearings. Needle bearings are good, but not great. Industrial bearings give these converters the ability to handle not hundreds, but thousands of pounds of torque. Thatís much better then the higher priced alternative converters.
Aircraft Aluminum Washers - NO FIBER. ACC converters utilize an aircraft quality aluminum washer instead of those old fiber washers that other companies use. This allows for more horsepower and torque capabilities.
NO Automation - ALL HAND BUILT. ACC Performance torque converters are hand built and tested to ensure that you are getting the best converter money can buy. No automated process can ensure that you will get that kind of quality. Made here in the USA. (You old school people may remember ACC as Alabama Converters)."
5" Autometer Tach $75.00 shipped
2002 350 warrior $1600.00
New parts as follows-
-starter
-battery
-axle bearings
-swing arm bushings
-handle bars
-grips
-intake
-both sprockets
-chain
-grab bar
Has lots of mods and aftermarket parts, pipe, jetting, wheels and tires, nerf bars, wheels ect.
Very fast quad. Runs great. Engine does smoke upon start up when it sits for awhile but goes away after running for a short period of time.
[email protected] thanks Troy or 765-541-0577
Keep talking, your making me famous
monster514stang is offline
post #2 of 14 (permalink) Old 02-11-2009, 09:39 AM Thread Starter
make offers
post #3 of 14 (permalink) Old 02-13-2009, 02:57 PM
bcnelson43
that stall would work for me can you send a pic to me thanks
there's nothing better than a BBF
bcnelson43 is offline
post #4 of 14 (permalink) Old 02-14-2009, 06:58 PM Thread Starter
PM sent
post #5 of 14 (permalink) Old 02-14-2009, 06:59 PM Thread Starter
quad is sold
post #6 of 14 (permalink) Old 02-14-2009, 07:02 PM Thread Starter
I would trade convertors with someone. I need one in the 2800-3200 range.
post #7 of 14 (permalink) Old 02-15-2009, 07:35 AM
nuclearcobra's Avatar
What motor combo and car was the converter used with?
nuclearcobra is offline
post #8 of 14 (permalink) Old 02-15-2009, 08:10 AM
E-mail sent.
Glenn M. is offline
post #9 of 14 (permalink) Old 02-15-2009, 05:57 PM Thread Starter
514 in a four wheeldrive, has less than 200 road miles
post #10 of 14 (permalink) Old 02-17-2009, 04:47 PM Thread Starter
Intake is sold
post #11 of 14 (permalink) Old 02-24-2009, 09:31 PM
jcoxracing's Avatar
Thanks for the tach. Nice doing business with you
Thanks again
Justin
jcoxracing is offline
post #12 of 14 (permalink) Old 02-25-2009, 05:28 AM Thread Starter
Thanks again
Justin
Thank you Justin
post #13 of 14 (permalink) Old 02-25-2009, 05:29 AM Thread Starter
All is sold, close the thread
post #14 of 14 (permalink) Old 02-25-2009, 05:32 AM
frank13's Avatar
Quoted: 9 Post(s)
Send a message via AIM to frank13
in your first post, on the right side, there is a tab labeled thread tools, click then click on close thread....just dont delete it incase we need to come back to it
frank13 is offline
