parting out 96 F150 4x4 5.8, dual tanks, wiring harness, 5 speed etc... - 460 Ford Forum
post #1 of 16 (permalink) Old 02-26-2009, 07:40 PM Thread Starter
Behemoth DT's Avatar
Engine is available again. Deal fell through. Another wife block.
*complete 5.8 EFI engine, accessories, computer, wiring, dual tanks, etc. --$300-- pickup only
*Small block bolt pattern electronic overdrive automatic transmission --$50
*transfer case--$50
*front F150 4wd axle--$50
*driveshaft--sale pending
*my buddy also has a small block 5 speed od out of a full size late 80's to early 90's 2wd truck that he wants $200 for
If you want to convert your 2wd to 4x4, here you go. Engine
runs good, didn't get to try the transmission/t-case/front
end, but the PO said they worked.
This truck has no title, and the back half of the frame and
rearend were turned into a trailer before I came accross it.
I'm gonna charge core price for these parts($50 each major
drivetrain component), because I won't know for sure what
works, although the PO said everything worked fine. It will
be about a year before I'll get to test any of them, and if
they work, their prices will go up. Whatever you buy will
come with the wiring, etc. that you need. First come, first
served. I'm not trying to make a bunch of money on this
stuff, just trying to make back the money I invested for the
body.
Call me if interested. I work nights so definitely leave a
message. 270 230 7015
[email protected]
[email protected]
270 287 8663--Jake's cell
Leitchfield, KY 42754
www.BehemothDrivetrain.com Strong Box - Planetary Underdrive Gearbox
Behemoth DT is offline
post #2 of 16 (permalink) Old 02-27-2009, 09:51 AM
InfoFord's Avatar
need a dash pad for one in excellent shape
InfoFord is offline
post #3 of 16 (permalink) Old 02-27-2009, 11:44 AM Thread Starter
im keeping the cab
[email protected]
post #4 of 16 (permalink) Old 02-27-2009, 06:11 PM
waypastcrazy's Avatar
Hey have a 95 but its not mass air it is speed density. Is your 96 mass air or speed density. I may be interested if its mass air. I know. The 5.0 was mass but wondering if the 351s ever got the mass air option also what brake rotor setup was 96 the slip on or bolt on my 95 is bolt on but I read that they changed it in later 95 and 96 thx clyde
Boss!boss! Da!plane da! Plane!
waypastcrazy is offline
post #5 of 16 (permalink) Old 02-28-2009, 05:52 AM
I am interested in the front driveshaft if you want to sell seperate.Bryan
olds492 is offline
post #6 of 16 (permalink) Old 02-28-2009, 09:58 PM Thread Starter
I dunno about the mass air. You tell me what to look for, or what to take a pic of and I'll do it. As for the rotors, maybe you can tell from these pics... if not, again, tell me what to look for and I will.
Bryan, I will sell the driveshaft for $50 shipped to 48 states, but it may be a week or so before I can get it out. Let me know if you're interested.
This truck has no title, and the back half of the frame and rearend were turned into a trailer before I came accross it. I might try to hook up the tank on this thing and get a video of it running on youtube, but the price might go up a little. Got a guy from Penn. may come and pick up the tranny for $75 (core price).
I'm gonna charge core price for these parts untill I can get video of it running, but whatever you buy will come with the wiring, etc. that you need. First come, first served. I'm not trying to make a bunch of money on this stuff, just trying to make back the money I invested for the body. Thanks guys.
[email protected]
post #7 of 16 (permalink) Old 03-01-2009, 12:49 AM Thread Starter
By the way, if someone wants to buy the heads/intake and all wiring, etc. without the shortblock, I may be able to ship. This should allow you to convert your 351w from carb to EFI. Please research this yourself, and make sure it will work. $350 shipped to 48 states.
[email protected]
post #8 of 16 (permalink) Old 03-01-2009, 12:53 PM
droppedf100's Avatar
Quoted: 6 Post(s)
How many miles are on the engine?
droppedf100 is offline
post #9 of 16 (permalink) Old 03-12-2009, 03:52 PM Thread Starter
ad updated. Bump
[email protected]
post #10 of 16 (permalink) Old 03-12-2009, 06:18 PM
InfoFord's Avatar
still interested in the dash pad
and if the mirrors are power be interested in them as well
InfoFord is offline
post #11 of 16 (permalink) Old 03-12-2009, 06:22 PM Thread Starter
Sorry, but I am keeping all things body for my 90 F350 4x4. That's the only reason I bought the truck.
[email protected]
post #12 of 16 (permalink) Old 03-21-2009, 12:19 AM Thread Starter
By the way guys. My brother backed out of buying the motor, so it is also up for grabs.
*engine and all accessories, throttle body to oil pan, all wiring, computer, dual tanks, starter, etc. $300 pickup only
[email protected]
post #13 of 16 (permalink) Old 03-21-2009, 05:10 AM
Larry T's Avatar
what do you want for the air conditioner?please check the j tube filter to see if it has metal shaveings if it does then im not interested,most likely the pump is bad.
passenger side seat arm rest are you going to sale that?
Larry T is offline
post #14 of 16 (permalink) Old 03-21-2009, 01:37 PM Thread Starter
You are wanting the pump only, or the condensor, etc..? I will check it sometime this week.
I'm keeping all interior/ body.
[email protected]
post #15 of 16 (permalink) Old 03-21-2009, 05:59 PM
Larry T's Avatar
yes im talking about the pump and possably the black dryer canaster.in your post #4 picture passenger side the j tube filter is located in the hose with the clip below the dryer canaster.you will have to blede off the presure of the system befor you can remove the clip.once the hose is apart you can see the filter in the lower hose.you may have to use a pick or something to pull it out.if the filter has metal bits in it most likely the pump is bad or soon will be.
Larry T is offline
