460 Crate Engine - Street Hustler - Turnkey - 460 Ford Forum
post #1 of 29 (permalink) Old 04-02-2009, 10:58 AM Thread Starter
CarsByCarl's Avatar
Quoted: 186 Post(s)
460 Crate Engine - New - Turnkey (w/video)
This engine has been SOLD. (please call if you'd like us to build something similar)
Click HERE to see a video of the engine running on the dyno.
I am offering this engine for only $4950.00.
-test fire, break-in and dyno tune, $850.00
-Ford Motorsport valve covers, $150.00
-750cfm Holley carburator +$300.00
-Distributor with Crane XRi ignition, Crane coil and Ford Motorsport plug wires +$250.00
Turnkey package includes carburator, distributor, ignition, coil, plugwires, and plugs. Everything pictured below is included. Just connect gas and 12V, and you're ready to run.
Street Hustler Package:
-460 Cubic Inches (+.040 bore / 468 CID)
-Holley 3310 750cfm carburator
-Crane XR-i ignition with adjustable rev limiter
-Crane PS-20 coil
-New distributor cap and rotor
-Ford remanufactured distributor
-Ford Motorsport plug wires
-Ford Motorcraft spark plugs
-Ford FL1A oil filter
-Ported D3VE iron heads, new guides, hardened exhuast seats
-New CJ size valves
-Lunati springs, retainers, locks
-Scorpion roller rockers
-Crane stud conversion
-TFS pushrods
-Lunati Hydraulic flat tappet cam
-Lunati Hydraulic lifters
-Cloyes double roller timing chain
-Stainless exterior bolts
-Ford rear sump oil pan
-Melling high volume oil pump
-Ford remanufactured water pump
-Stealth Dual Plane Aluminum intake
-Hyper pistons
-Reconditioned stock rods
-Reconditioned stock crank
-Stock harmonic damper
-King main bearings
-King rod bearings
-ACL cam bearings
-Dyno tested and proven combination
-Premium Unleaded pump gas compatible
-All clearances and specs checked and documented
CarsByCarl is offline
post #2 of 29 (permalink) Old 04-03-2009, 08:28 AM Thread Starter
CarsByCarl's Avatar
Quoted: 186 Post(s)
bump...
post #3 of 29 (permalink) Old 04-03-2009, 08:49 AM
Location: Deployed to Okinawa Japan but call East Tenn home
Do you take payments, on any of your engines?
Nitrous is like a hot chick with STD'S you know you wanna hit it, but your afraid of the consequences.
purecountry is offline
post #4 of 29 (permalink) Old 04-03-2009, 09:26 AM
Send a message via AIM to pimpmobile
holy crap thats a flat torque curve. whats the LSA on that cam to give the peak to the torque curve like that? 112? Would you sell it without the carb and manifold?
pimpmobile is offline
post #5 of 29 (permalink) Old 04-03-2009, 09:58 AM Thread Starter
CarsByCarl's Avatar
Quoted: 186 Post(s)
Not directly, but I may be able to help you find financing if needed. PM me if interested.
post #6 of 29 (permalink) Old 04-03-2009, 10:03 AM Thread Starter
CarsByCarl's Avatar
Quoted: 186 Post(s)
I will sell without the carb/intake, but you'd be $$$ ahead selling them yourself. PM, call or email me for details. Thanks.
post #7 of 29 (permalink) Old 04-04-2009, 11:12 AM Thread Starter
CarsByCarl's Avatar
Quoted: 186 Post(s)
Bump for the weekend.
post #8 of 29 (permalink) Old 04-04-2009, 11:22 AM
IcallhimGeorge's Avatar
Send a message via AIM to IcallhimGeorge
Carl is a great guy to do business with. Service after the sale is A++ as well.
One more bump for you.
Kris
George is the trucks name.
"Street Head Mafia"
IcallhimGeorge is offline
post #9 of 29 (permalink) Old 04-08-2009, 08:33 AM Thread Starter
CarsByCarl's Avatar
Quoted: 186 Post(s)
Thanks Kris
post #10 of 29 (permalink) Old 05-21-2009, 09:27 AM Thread Starter
CarsByCarl's Avatar
Quoted: 186 Post(s)
Still available.
post #11 of 29 (permalink) Old 06-03-2009, 02:27 PM Thread Starter
CarsByCarl's Avatar
Quoted: 186 Post(s)
post #12 of 29 (permalink) Old 06-17-2009, 10:19 AM Thread Starter
CarsByCarl's Avatar
Quoted: 186 Post(s)
Engine is painted with early Ford dark blue. (flash in the pictures makes it look lighter).
post #13 of 29 (permalink) Old 06-17-2009, 12:44 PM
wheres the dyno numbers? did i miss it somewhere?
bottomland4x4 is offline
post #14 of 29 (permalink) Old 06-17-2009, 01:32 PM Thread Starter
CarsByCarl's Avatar
Quoted: 186 Post(s)
This particular engine made 470 HP and 525 lb/ft with dented/dinged 1-3/4" truck headers and a conservative tune. Similar results should be expected with shorty headers. Full length headers with larger primaries and a more aggresive tune would yield better results.
post #15 of 29 (permalink) Old 06-26-2009, 12:08 PM Thread Starter
CarsByCarl's Avatar
Quoted: 186 Post(s)
