466 F/S - 460 Ford Forum
post #1 of 3 (permalink) Old 04-02-2009, 07:43 PM Thread Starter
466 F/S
I have a 460 30 overr 466, Kb pistons flat tops stock rods with 190000 psi rod bolts oil mods, high volume pump, ARP bolts in mains, clevite bearings, d2ve heads ported intake and exhaust, comp cam springs, comp cam cam and double roller timing chain,comes with factory front sump pan and valve covers, motor has approx 1000 miles on it going with a diffrent set up you can hear run its in a 71 cobra torino right know. All you need is front dampner internal balance, dist, intake and carb. $1200.00 located in Michigan can make arrangements to meet half way with in a 100 miles or can ship which will be extra Joe. This motor ran 12.9 in a 4000 lb torino. Will sell short block for $1000.00
torinojoe1971 is offline
post #2 of 3 (permalink) Old 05-16-2009, 09:00 AM
Quoted: 11 Post(s)
Did you ever sell your short block? Where in Michigan are you located?
djmac is offline
post #3 of 3 (permalink) Old 05-16-2009, 01:37 PM Thread Starter
I still have the motor for sale its in my torino can hear run. I'm located in farmington hills Joe.
