501 Stroker Motor - 460 Ford Forum
post #1 of 3 (permalink) Old 05-20-2009, 02:43 PM Thread Starter
501 Stroker Motor
FORD 501 STROKER MOTOR $2,000 (plus freight charges via UPS Freight) Call (912)920-6687
This is a standard 2-bolt main 385-series Ford Big Block (370, 429, 460, and 514). The block is a D1VE-6015-AA casting. It has been inspected, cleaned, magna-fluxed, and pressure tested. It has been bored 0.030 over stock, 0.020 taken off the deck, and honed 30. The block was prepped and painted with Black VHT High-Temperature Engine Enamel.
CRANK SHAFT
Eagle Specialty Products (PN: 104604140) (Cost $278.67)
Internally balanced
Cast steel
Uses OE bearings
Stroke 4.140
Rod Length 6.700
Bob Weight 2350 grams
Rod Journal 2.200
Main Journal 3.000
PISTONS
Sportsman Racing Products (PN: 154166) (Cost $598.99)
Ford Big Block Inverted Dome Series
4032 low expansion, high silicone aluminum alloy, heat treated to SRP specifications
Pistons are cut for SCJ Heads
CNC machined ring grooves accept 1/16, 1/16, 3/16 rings
JE Pistons Straight Wall Wrist Pins: .990 x 2.930 x .150
Total Seal High Performance Piston Rings
Bore 4.390 (.030 over)
Stroke 4.140
Rod Length 6.700
Compression Distance 1.520
Piston Weight 620 grams
Inverted Dome -28cc
Compression Ratio w/Heads
72 cc Chamber 9.9:1
80 cc Chamber 9.5:1
84 cc Chamber 8.9:1
CONNECTING RODS
Eagle Specialty Products (PN: CRS-6700-3D) (Cost $466.67)
"ESP" H-Beam Connecting Rod
Standard Forged 4340 Steel
ARP 8740 7/16" fasteners
Length 6.700
Rod Journal 2.200
Pin Size .990
Thickness above Pin .220
Weight 815 grams
CAMSHAFT
COMP Cams (PN: 34-341-4) (Cost $129.95)
282S Solid Magnum
This cam features a broad power curve and torque range with a mild rough idle.
Double Roller Timing Chain
RPM Range 2000-6000
Duration Int/Exh 236 @ .050
Valve Lift .570 with 1.73" rockers
MAIN BEARINGS
Clevite 77 Performance (PN: MS-1039 V) (Cost $61.95)
CONNECTING ROD BEARINGS
Clevite 77 Performance (PN: CB-743 H) (Cost $88.00)
FASTENERS
Automotive Racing Products (PN:155-5402) (Cost $59.95)
For pictures go to: http://cgi.ebay.com/ebaymotors/ws/eB...m=260414200569
bci_moss is offline
post #2 of 3 (permalink) Old 05-20-2009, 03:54 PM
Diggindeeper's Avatar
Auction rules #2, and 3. Please read.
Diggindeeper is offline
post #3 of 3 (permalink) Old 05-27-2009, 10:40 PM Thread Starter
The motor is in Pooler, GA. It is listed on other sites, including eBay. The first contact will be honored, whether it is from this forum or not.
bci_moss is offline
