5.0 tt full kit $1200 or trade for BBF - 460 Ford Forum
post #1 of 1 (permalink) Old 01-06-2010, 07:41 PM Thread Starter
darkmyth's Avatar
Brand new “street” twin turbo package for 1979 - 1993 Ford Mustang 5.0L. This package has all new parts that is capable of producing 500 horsepower .
Includes a cooling solution for a hot turbocharged engine featuring a high flow-cooling fan and oil cooler kit. Also, the included electronic turbo timer provides a hassle-free operation of precisely calculating the cool down period to ensure a proper cool down for your turbocharged motor. On a stock motor the kit will add amazing horsepower on a low boost setting of 8-10 PSI.
looking for 1100 full kit yes it is a eBay kit but it has other parts too that make it a full kit
(8) 39lb fuel injectors: ford racing
holds up to 500hp
(2) turbo flanges:
for downpipe
(1) 255 fuel pump:
holds up to 500hp
(2) Hybrid Turbo Charger:
.57 compressor wheel trim mapped for low & high boost setups
Oil fitting gaskets & mounting studs included
Capable of producing over 450 horsepower
wet float bearings & properly balanced
3" inlet diameter with a 2" outlet
.50 A/R compressor housing
.63 A/R turbine housing
1/8 NPT oil inlet
T3/T4 hybrid
(2) Turbo Exhaust Manifolds:
High quality gaskets included for turbo flanges and exhaust manifold flanges
TIG welded 321 Stainless steel material for longevity and strength
Support brackets welded on help support the weight of the turbo
High quality tubular piping with large 1 5/8" primaries
Full install kit includes all bolts and hardware
Extra thick flanges support the turbos well
Beautifully polished for a show finish
High quality T3 turbocharger flange
Fully ported and polished design
(1) Front Mount Intercooler:
Large design cools down the turbocharged air efficiently
Strong TIG welds will support high PSI levels
Lightweight aluminum racing intercooler
Brackets create a easy bolt on design
3" cold outlet and 2.25" hot inlets
(2) Turbo Oil Line Install Package:
T fittings will fit almost any motor & still use factory oil pressure sending unit
Necessary fittings and clamps for a complete installation
18 inch 5/8” high temperature 550psi oil return line
Premium gaskets & hardware for the turbocharger
77 inch straight high strength oil feed line
Strong "T" fitting to hook up to block
Superior quality lasts a lifetime
Retails for $229 in magazines
High quality oil feed fittings
High quality turbo oil drain
Brand new turbo install kit
36 inch angle oil fee line
(1)Direct Fit Intercooler Piping Kit:
Complete set of reinforced silicone couplers
High quality T-Bolt clamps included
Direct bolt on (not universal piping)
Lightweight aluminum piping
(1) Boost Controller:
Can be setup to adjust boost PSI on the fly
Can be adjusted for any PSI level desired
Control your boost with a precise click
Includes complete install kit
Anodized aluminum finish
CNC machined design
(2) Blow Off Valves:
Protects the turbo by letting pressure surges vent when shifting and/or reducing throttle
Performance design produces a powerful and aggressive sound
Quality design will not leak under high boost conditions
Flanges can be installed at user discretion
(1) Slim Cooling Fan:
Fan can be used to cool: A/C condenser, oil or transmission cooler, mounting on an intercooler to prevent heat soak, or cooling a a2w radiator
Slim design provides excellent engine bay clearance
Includes the mounting tabs for a easy zip tie install
Reversible design can either pull or push air
Versatility of a push/pull reversible fan
Superior flow of a curved-blade design
Creates additional aftermarket cooling
1.25" thick outside perimeter
2.50" thick inside perimeter
(1) Electronic Turbo Timer:
Ensures a proper cool down for your turbocharged car every time
Includes pigtail wiring and extra wiring for ease of installation
Important to preventing premature turbo wear and failure
Mounted inside the vehicle for on the fly adjustments
Precisely calculates the cool down period for the motor
Auto mode feature creates a hassle-free operation
Increases turbocharger's operating lifespan
Bright Easy to read LED Digital Display
Failure to reduce the temperature of the turbo could result in "coking" of oil inside the turbo
Coking is the baking of oil, turning it into a grimy substance
(2) 35mm Wastegates:
Protect the turbo system from over boosting
Anodized blue show like finish
V-band clamp style
(1) Fuel Pressure Regulator:
Great to setup fuel pressure for boosted engines
Precision pressure gauge
Fully adjustable
(1) Catch Can:
Stops excess oil from blowing to the intake manifold
Ensures better mileage & better performance
Removes oil vapors from breather line
Show like high quality polish
(1) Oil cooler Kit:
If the engine already features a factory oil cooler, this oil kit can still be used together with the OEM cooler kit
Cooler core has 15 rows which is perfect for cooling hot engine oil(a cooler that is larger will not be efficient)
Plate features 1/8” NPT ports for oil pressure & temperate sensors for gauges or for turbo oil feed lines
Cooler can be mounted in direct airflow or hidden & it will still do its job of cooling
Oil Line fittings are machine crimped & checked to prevent leaks
Cooler features 4 strong brackets for a sturdy & easy installation
(2) Stainless steel lines feature aluminum racing swivel fittings
Bar & fin core design is very effective at cooling hot engine oil
7/8” Oil lines are fully reinforced with braided stainless steel
Oil lines resist engine bay heat & can support over 200 PSI
Oil lines are high quality & 4.4 ft. long each (52 inches)
Cooler measures 13” long x 5.5” wide x 2” thick
Cools hot engine oil by over 20 degrees
CNC milled billet aluminum oil plate
Oil filter adapter has 1.5mm threads
Oil cooler is lightweight aluminum
(1) Billet Aluminum High Flow Fuel Filter:
CNC machined T6-6061 billet aluminum construction
High flow capacity for demanding fuel systems
Strong brackets for easy mounting
High pressure fuel fittings
Anodized show like finish
Filter can be cleaned
6an sized fittings
Removable filter
(1) Coolant Sensor Bung
Monitor the water temperature via this sensor relocator
Provides more precise readings then the stock location
Features 2 installation clamps for an easy add on
Easy solution to run aftermarket coolant sensor
38mm ends fits most OEM coolant hoses
Strong Aluminum construction
Applications
Fits the following vehicles with specified engine:
5.0 Thunderbird (kit requires some fabrication)
5.0L swapped engine vehicles
cash only call Will trade for BBF motors 460ci and up with a 36" long c6 trans would be a plus me at (214) 536-8000 can email pics or text them too 1200 or trade for the above
darkmyth is offline
