500" BBF EX-514 Headed 91 Octane Drag Race Motor - 460 Ford Forum
post #1 of 12 (permalink) Old 01-15-2010, 05:06 PM Thread Starter
hallbros's Avatar
NEW PRICE!!! $7500 including coated headers for chassis car!!
Pics added below!
This is the motor out of my 56' Ford that I just sold as a roller. I will list all my spares and extra parts soon as well.
$8500 Carb to pan
Here is a link to my other ad where you can see some pics of the build. First ran it in late 2007, rings have about 250 passes on them and the springs and lifters have about a 100.
https://www.460ford.com/forum/showthread.php?t=135733
I have never dynoed the motor but the car weighed 2950 with me in it and went 9.59 @ 142 mph best at sea level. This is leaving the line soft at only 1.36 60' time. Match a converter to this cam and it will pick up quite a bit more.
Motor:
Fresh spring 2008. New springs, lifters and poly locks 2009
Dove-C 4 bolt Cobra jet block .030 over.
A460 style Aluminum heads by Extreme Machine(EX-514).
LA Billet Kryptonite crank 4.125 stroke, BBC rod journals and snout. Double keyed.
6.800" Scat 4340 H-Beam rods with bolt upgrade.(new 2008)
Ross pistons (10:1 compression @ 80cc). (3 extra balanced as well)
Lunati Cam .770/.750 285/295 @ .050.(new 2008)
Milodon Gear drive.
Billet rail fabricated valve cover with 12an on front(very nicely made)
Ford Motorsport A460 Dominator intake (Powdercoated very nice).
Crower stainless rockers.(new 2009)
Garrett machine A460 stud girdle.
Manley valves.(new 2008)
Jeff Johnston billet fab chassis car pan.(holds 17 qts.)
Titan billet alum. oil pump.
Mezeire polished elec. water pump.(new 2008)
Isky Red Zone lifters(new 2009)
ATI SFI balancer
Comp Cams valve springs (new 2009)
Holley 1050 cfm 3 circuit dominator(new style)
HVH Supersucker carb spacer
MSD distributor(locked out and bronze gear)
Taylor race series wires
Nice hi-torque mini starter
TCI SFI flexplate(not the cheap SFI, the good one)
916-974-0236
Cliff Hall
Hall Bros Racing
hallbros is offline
post #2 of 12 (permalink) Old 01-15-2010, 05:38 PM
powerstrokeace's Avatar
Is this the same motor that had the blower on it?
Ace
powerstrokeace is offline
post #3 of 12 (permalink) Old 01-15-2010, 06:07 PM Thread Starter
hallbros's Avatar
The pistons, crank, oil pump, main girdle, head stud girdle and oil pan are the only holdovers from the blower motor....and the bare head castings. I had to replace everything else at one time or another....filled block, alum. rods....etc. Good memory!! lol.
Cliff Hall
Hall Bros Racing
hallbros is offline
post #4 of 12 (permalink) Old 01-17-2010, 08:17 AM Thread Starter
hallbros's Avatar
Here are some pics of the build in 2007.
Cliff Hall
Hall Bros Racing
hallbros is offline
post #5 of 12 (permalink) Old 01-18-2010, 06:05 PM Thread Starter
hallbros's Avatar
Arp main, head and oil pan studs.
Crankshaft is double keyed.
Exhaust ports are studded for easy header installation as well.
Cliff Hall
Hall Bros Racing
hallbros is offline
post #6 of 12 (permalink) Old 01-20-2010, 11:19 AM Thread Starter
hallbros's Avatar
ttt...
Cliff Hall
Hall Bros Racing
hallbros is offline
post #7 of 12 (permalink) Old 01-23-2010, 03:36 PM Thread Starter
hallbros's Avatar
Any interest before I start parting it out? It is currently bolted to an A-1 Performance built glide that was just freshened spring 2009. Stock case but all good parts inside. Uses the TCI adapter plate kit which was doubling as a mid plate in my car.
I would make someone a great deal on the combo.
Cliff Hall
Hall Bros Racing
hallbros is offline
post #8 of 12 (permalink) Old 02-07-2010, 04:04 PM Thread Starter
hallbros's Avatar
Trans sold! Anybody looking for a stout, low maintenance turn key motor.......carb to pan, dist. included, just drop it in and go. Nice set of tube chassis coated headers and a nice Glide adapter plate/flexplate combo could be included for the right deal.
Anyone?
Cliff Hall
Hall Bros Racing
hallbros is offline
post #9 of 12 (permalink) Old 03-05-2010, 03:07 PM Thread Starter
hallbros's Avatar
ttt
Cliff Hall
Hall Bros Racing
hallbros is offline
post #10 of 12 (permalink) Old 03-17-2010, 11:33 PM Thread Starter
hallbros's Avatar
NEW PRICE!!! See above!!
Cliff Hall
Hall Bros Racing
hallbros is offline
post #11 of 12 (permalink) Old 03-18-2010, 05:22 PM
Bigmike321's Avatar
Will you let the dizzy go by its self???
Bigmike321 is offline
post #12 of 12 (permalink) Old 03-18-2010, 06:17 PM Thread Starter
hallbros's Avatar
Stay tuned Mike, if it doesn't sell soon I will part it out, I'll be looking for about $175 to your door for the dizzy if it happens.
Thanks.
Cliff Hall
Hall Bros Racing
hallbros is offline
