550hp 466 bbf rllr,H bm,frgd,dmn crb$1500 - 460 Ford Forum
post #1 of 5 (permalink) Old 01-21-2010, 08:45 PM Thread Starter
d1ve .030 eagle H beams,sealed power light weight pistons,balanced,ARP main studs,[email protected] 650"tight lash solid roller,comp rollers,3/8 pushrods&guide plates,pro magnum rockers,victor intake(4150)850 demon carb,victor alum water pump,L&L truck motor mounts& p/s bracket,2wd truck headers,1 ported dove-c with 2.25,1 stock dove-c(needs to be matched)roller springs,motor sports chain,moroso drag pan,crank & wpump pulleys,TCI super street fighter convter,new gasket set,bearings,moly rings,needs assembling $1500 334 321 1594 Alabama. Also stock D1VE 429 short block has been checked will build standard.have all rotating assembly $300
joelmoncrief is offline
post #2 of 5 (permalink) Old 02-10-2010, 11:07 AM
So is the engine apart now then? 1 ported and 1 unported head?
Underpressure557 is offline
post #3 of 5 (permalink) Old 02-16-2010, 08:21 PM
also curious, apart or together?
ehummelman is offline
post #4 of 5 (permalink) Old 02-16-2010, 10:42 PM
Greenbroncoguy's Avatar
Send a message via Yahoo to Greenbroncoguy
I am assuming that this engine has been run and torn down, or are these mostly new parts???
If it was previously ran, why was it torn down?
-Matt
Greenbroncoguy is offline
post #5 of 5 (permalink) Old 02-17-2010, 08:52 AM
d1ve .030
eagle H beams
ARP main studs
comp rollers
3/8 pushrods & guide plates
pro magnum rockers
victor intake(
4150)850 demon carb
L&L truck motor mounts & p/s bracket
2wd truck headers
roller springs
motor sports chain
moroso drag pan
crank & w pump pulleys
new gasket set
bearings
moly rings
334 321 1594
Alabama.
Also
I HOPE THIS IS OK
I HAD A HARD TIME READING YOUR ADD
George
{ Your Are Never To Old To Learn }
GFPRACING is offline
