545 rotating assembly - 460 Ford Forum
post #1 of 7 (permalink) Old 02-10-2010, 04:03 PM Thread Starter
466fox's Avatar
Used 4.5 cast crank, .030 over ross 13 to 1 pistons for A460 heads, scat steel h-beam rods with arp2000 bolt upgrade. I also have rings and bearings for this if interested. $800 pm me for more details. I also have a solid roller cam to go with this for $100, this combo with the A-heads made a little over 900hp in a stock block. Crankshaft and rods have no more than 30 passes on them.
[email protected] in the 1/8
3100lbs, true 29\10.5
Homegrown HP
http://www.youtube.com/watch?v=OxvD5..._order&list=UL
466fox is offline
post #2 of 7 (permalink) Old 02-10-2010, 11:57 PM
powerstrokeace's Avatar
Flat top pistons?
Ace
powerstrokeace is offline
post #3 of 7 (permalink) Old 02-11-2010, 07:49 AM
crittersf1's Avatar
What length rod?
crittersf1 is offline
post #4 of 7 (permalink) Old 02-11-2010, 08:49 AM
rvesterby's Avatar
545 setup
Are all the pieces balanced as an assembly ??? assume so as you said 30 passes
Tomorrow is the first day of the rest of your life. Lets go racing !!
rvesterby is offline
post #5 of 7 (permalink) Old 02-11-2010, 09:01 PM
can it be used with dove heads
johndickjr is offline
post #6 of 7 (permalink) Old 02-11-2010, 09:26 PM
CrankShaft Manufacturer
Who makes the cast crank you are selling
Hermancar is offline
post #7 of 7 (permalink) Old 02-12-2010, 09:41 PM Thread Starter
466fox's Avatar
SOLD
Homegrown HP
466fox is offline
