501 bbf short block ++ - 460 Ford Forum
post #1 of 6 (permalink) Old 03-22-2010, 11:27 AM Thread Starter
d9 2 bolt Block w/ARP main studs.030 over,Scat 9000 4.14 crank,Eagle rods, JE srp piston flat top with Ford valve notches, Comp cams 304BR-8 roller cam (no Lifters), Moroso 7 QT open chassis oil pan w/windage tray ,moroso sump and hp ford pump,new timing cover and chain set. Externaly balance with ford counter weight, profesional products balancer and a cat flexplate. Block was decked, bored and honed with torque plate, align honed etc. Never run, have a set of ARP head studs also.
complete as stated $2950 obo + freight
Or
Short block only
(No pan/sump/pump ,cam,Head studs) $2,250. obo+ freight
Or
Will sale rotating assembley complete and balanced for
1050.00 + ride
Located northeast PA
No-junk, if it sells I'm trying to buy a complete motor localy. If not it's going in the dragster
PM me for picks and more info
[email protected]
sskwb is offline
post #2 of 6 (permalink) Old 03-22-2010, 01:50 PM
hookin78's Avatar
How far under deck are these pistons at TDC?
hookin78 is offline
post #3 of 6 (permalink) Old 03-22-2010, 06:57 PM Thread Starter
in the hole .016
sskwb is offline
post #4 of 6 (permalink) Old 03-23-2010, 02:53 PM Thread Starter
Added to the add:
1050.00 + ride
sskwb is offline
post #5 of 6 (permalink) Old 03-23-2010, 07:20 PM
weldonj's Avatar
what length are the rods for this, and are they H-beam? Also whats the comp ratio with 72-74cc heads?
weldonj is offline
post #6 of 6 (permalink) Old 03-23-2010, 07:51 PM Thread Starter
pm sent
sskwb is offline
