725+HP E85 Crate Engine Special $7250.00 - 460 Ford Forum
post #1 of 1 (permalink) Old 03-25-2010, 10:50 AM Thread Starter
CarsByCarl's Avatar
Quoted: 186 Post(s)
For a limited time, I will be discounting my Mean Machine E85 crate engine by $500.00 and including a baffled Ford/Canton oil pan at no additional charge.
Gas prices are going back up. Oil is expected to hit $100/bbl again. This engine is the solution to the problem. Race gas power at pump gas prices! Low maintanence flat tappet cam allows you to drive on the interstate all day.....with 725+HP on tap!
Mean Machine Crate Engine
-Designed specifically for e85 fuel
-Race gas power for 1/4 the cost!
-Choice of 501/521/545 rotating assemblies
-Forged Crank, aircraft certified 4340, internal balance
-Forged 4340 connecting rods
-Diamond Forged pistons
-Diamond file fit plasma moly rings
-Ported Ford Motorsport SCJ Aluminum heads
-Ford Racing Victor Aluminum intake
-Scorpion Roller Rockers
-Choice of Ford Motorsport
-Oil pan included at no additional cost for a limited time only
-3/8" custom pushrods
-Lunati solid flat tappet camshaft
-Lunati flat tappet lifters
-High flow Dynamics Stage 1 oil pump
-Power potential 725+ HP at 5750 rpm, 725+ lb/ft at 4250 rpm
-e85 fuel required
-e85 carb conversions available, starting at $300.00
-Custom options available
Why should you use e85?
-e85 is American made
-e85 costs ~25% less than premium unleaded and ~75% less than race gas
-e85 runs cooler than gasoline
-e85 engines have ZERO net c02 emmisions (less than any hybrid! )
CarsByCarl is offline
