I want to add a turbo to my diesel. - 460 Ford Forum
post #1 of 10 (permalink) Old 08-31-2010, 05:49 PM Thread Starter
Behemoth DT's Avatar
I want to convert my 93 IDI to a turbo. I can make adapters. I'd like to have a stock turbo from a 94-up to start with. Let me know what you have.
[email protected]
270 230 7015
[email protected]
270 287 8663--Jake's cell
Leitchfield, KY 42754
www.BehemothDrivetrain.com Strong Box - Planetary Underdrive Gearbox
Behemoth DT is offline
post #2 of 10 (permalink) Old 08-31-2010, 07:47 PM
richter69's Avatar
I've got one from a late 99, only has factory dyno time on it.
69 Grande'
P51 headed 563
3070#'s
5.15 @ 134.89
richter69 is offline
post #3 of 10 (permalink) Old 08-31-2010, 09:15 PM
Quoted: 11 Post(s)
You might already know this but the 94.5 and up powerstrokes make more boost than the 7.3 NA can handle. If you use a later turbo you will have to wastegate it accordingly. I think the 7.3 factory turbos in 93 and 94 only made about 7-9 lbs of boost and the most you could turn them up to is about 12-13 and i think and the powerstrokes are in the range of 20-30 i believe. Just a little info fwiw.
78 F250, 466/C6/205, EFI, Dana 60 4.88 spool, Ford 10.25 4.88 lincoln locker, Custom 4-link rear coil springs, Custom 3-link front coil springs, 39" Boggers on 12" Weld SS's (sold)
2006 Blue/Gray F250 4x4 CC 6.0 Torqshift NP273
79 F350, 521/T18/205, Dana 60 4.10 detroit, dana 70hd 4.10 Lincoln locker, 36" Rockers on 12" Eagles.dynoed at 628hp and 685ft/lbs torque at 5000rpms all iron
lonco is offline
post #4 of 10 (permalink) Old 08-31-2010, 09:27 PM
richter69's Avatar
This turbo I have has a wastegate, no pedestal, but the are easy to find.
69 Grande'
P51 headed 563
3070#'s
5.15 @ 134.89
post #5 of 10 (permalink) Old 08-31-2010, 09:49 PM
hookin78's Avatar
Keep in mind the boost level on these turbos are also relative to the amount of fuel you throw at the engine..... If you just bolt on either one of these turbos you wont see much boost..... Not near what you would see on engine they were origionally designed for..... UNLESS you turn up the fuel , there fore you can also limit the amout of boost VIA fuel. It is ultimatley horsepower that limits you on what the older engines can take, not boost.
Just a couple more pennys to add to the discusion.
hookin78 is offline
post #6 of 10 (permalink) Old 08-31-2010, 10:43 PM
too much boost on an idi has been known to egg shape the wrist pins even at 8-9 psi
whtstdhrse is offline
post #7 of 10 (permalink) Old 09-01-2010, 09:44 AM
A close friend of mine performed this conversion. As I understand the compression ration is like 3-5 points higher (or so we where told) in the IDI. We were a little worried about this but it seemed to like the added compression. He took everything off a crashed IDI-T truck and it worked great. I know he put more fuel in it and has been driving it for years. I pulled a racecar accross Texas with it and it ran better than the IDI-T truck that he crashed ever did. Good Luck Kevin S.
KEVIN S is offline
post #8 of 10 (permalink) Old 09-02-2010, 06:05 AM Thread Starter
I wonder how much a ram air hood would push in?
[email protected]
post #9 of 10 (permalink) Old 09-02-2010, 05:50 PM
Talking
Put a Cummins w/a Bosch p-pump in it
COBRA JET is offline
post #10 of 10 (permalink) Old 09-02-2010, 05:55 PM
x2
Derek
79' mustang 528/glide
[email protected]
derek528 is offline
