513 BBF Storker Motor $6500 OBO - 460 Ford Forum
post #1 of 5 (permalink) Old 09-13-2010, 12:45 PM Thread Starter
In a 3300lb mustang it went 10.10 at 136 on an easy pass. Real soft launch. I will sell this with everything needed to put in a foxbody. Also the bbf to C4 bell.
Started with a 71 460 block completely prepped, bored, honed with torque plates, Line bored you name it, also some special oil passage work for better oil flow has 80lbs of pressure, new rotating assembly thats internally balanced, there is a girdle on the mains, Motor has 10-1 compression, heads are a set of Aluminum Cobra Jet Heads with new valves 2.25 int and 1.76 exh I believe, heads are bolted down with ARP studs not standard arp bolts, new springs, new Comp Cams High Tech Stainless rocker arms 1.73 ratio $400 rockers, new Jomar Stud Girdles, heads have extensive port work done to them, has a belt drive, cam is a solid roller by Ultra Dyne 738int lift and 738 exh lift, electric water pump, Intake is a victor 460 ported to match heads, and on top of that is a new pro-systems carb built for this motor by Patrick James.
Call with any questions. Eric 240-441-6130
88GT513 is offline
post #2 of 5 (permalink) Old 09-13-2010, 12:58 PM Thread Starter
I forgot to mention the motor has 10-12 passes on it and about 20 street miles on it.
88GT513 is offline
post #3 of 5 (permalink) Old 09-13-2010, 09:16 PM
NITROUS FORD's Avatar
Talking
HOW MUCH HP!
NITROUS FORD is offline
post #4 of 5 (permalink) Old 09-13-2010, 10:09 PM Thread Starter
Without putting it on a dyno, I would say between 650-750.
88GT513 is offline
post #5 of 5 (permalink) Old 09-15-2010, 02:18 PM
with that mph, your real close. . .high 600's low 700's at the crank.
1967 Cyclone GT
1970 F100 SWB, 428
2003 Cobra, Kenne Bell, 305ci
64T-bolt is offline
