540 short block and other bbf parts - 460 Ford Forum
post #1 of 5 (permalink) Old 01-01-2011, 09:08 AM Thread Starter
1.i have a 540 short block assembled and ready for heads its a dove a studded 4 bolt main block punched .30 over scat crank shaft BME aluminum rods probe forged flat top pistions that are fly cut for cobra jet or a 460 heads high flow oil pmump stud gridle and windage tray has a 750 lift full roller cam drouble roller timing chain and balancer big truck oil pan was in a pulling truck run it is fresh was tore down and freshened this past fall asking $4000
2. weiand stealth intake 8012 model $120
3.RCI transmission scatter blanket $50
4. scat sfi approved flex plate $100
5. brand new set of SEC head gasket $100 {these are $60 each new from summit}
6.holley blue electric fuel pump $75
7.holley mechanical fuel pump rotating base 110 gph $75
8.electric fan 4500 cfm stock ford $50
9. c6 4x4 tranny set up for pulling reverse manual vavle body red alto clucthes servo up grade has aluminum 4407 t-case to go with it $800
my cell no. is 724-730-3662 im located on the ohio pa line near youngstown
fordman1979 is offline
post #2 of 5 (permalink) Old 01-01-2011, 10:55 AM
More info on:
please.
The Pope
77 F250 2wd, C6, Long Bed, HD Susp. Package.
Weiand Stealth 8012 IM, Holley 4150 750, MSD 6AL, Doug Thorley Headers (THY-211Y), 3" Dual Exh.
What I "Think" I want to build: 545ci, P-51 Heads, 10-10.5:1 cr, Hyd Roller Cam w/ solid roller lifters (?Isky’s EZ Roller Lifters?), Stealth 8021 IM, Street Gas, all with room to grow so that later I can use it to just strike fear in the eyes of them Chebby Guys!
The Pope is offline
post #3 of 5 (permalink) Old 01-01-2011, 06:57 PM Thread Starter
its from a mid 90's lincoln its the 2 speed fan i had it on a 4 core rad on my pulling truck you could stand in front of the truck and feel it draw air thru it also has the plug with about 6 inches of wire get me an e-mail and i can send you pics
post #4 of 5 (permalink) Old 01-01-2011, 08:40 PM
pm sent. Also how much $$$?
The Pope
The Pope is offline
post #5 of 5 (permalink) Old 01-02-2011, 03:42 PM
Thanks for the pics.
What are you wanting for it?
The Pope
The Pope is offline
