572 Huntsville engines BBF - 460 Ford Forum
post #1 of 31 (permalink) Old 01-04-2011, 09:27 AM Thread Starter
For sale : 572 ci BBF built by huntsville engines , motor has 50 passes since new . only thing reused is the head castings , everything else new out of the box. Motor is very strong and I have the dyno sheets to prove it , made great hp and torque , motor is set up for nitrous but has not been used , I did not need it to run the class that I was running and my chassis would not hold the power this motor made without it, best et is 5.60 with a 1.40 60ft hazing the tires the first 100 ft of the run . Motor was run 1/4 mile one time to see what it would run , 8.90 @ 164 pretty strong for a 3800 pound 1966 f-100 truck . Only reason for sell is I have no time to race , kids are into athletics and they always have something for me to attend so I decided to sell the motor instead of it sitting . I will list the parts below and I know I will miss some but you can call me and I can give you all the details . 334-534-1892
Parts list :
Ford SVO eliminator block 4.50 bore
Eagle 4340 crank 4.50 stroke
Eagle H beam rods
Diamond custom gas ported pistons ( 4 spares) Total seal rings
Coated bearrings
Danny B belt drive
Comp cams custom grind solid roller
A headed motor ( heads ported and set up by Kasse)
Trick flow intake cnc ported and matched to heads
Prosystems 1350 carb
5 stage dry sump oil system
Ati balancer
5 vane vaccum pump with adj relief valve
Aerospace mandrel drive for vaccum and oil system
Msd crank trigger and billet distr.
Pro shot fogger with stainless nozzles
I know I forgot some parts but call me if interested , Hp numbers to serious buyers only this motor is a beast and built to last . 13,500.00 takes it , you can't buy the parts for that.
66 hayhauler is offline
post #2 of 31 (permalink) Old 01-04-2011, 10:17 AM
1Bad65's Avatar
PM sent
1Bad65 is offline
post #3 of 31 (permalink) Old 01-04-2011, 01:08 PM
crittersf1's Avatar
Question
Be interested in "parting-out"?
crittersf1 is offline
post #4 of 31 (permalink) Old 01-08-2011, 03:46 PM Thread Starter
to the top
post #5 of 31 (permalink) Old 01-13-2011, 01:42 PM
motor
I have seen this truck run before it is BAD ,I think the truck was in a fast fords mag. they were showing some winning classes
spoon5 is offline
post #6 of 31 (permalink) Old 01-18-2011, 08:56 AM Thread Starter
to the top
post #7 of 31 (permalink) Old 01-18-2011, 10:59 AM
cheatham's Avatar
I cant buy it but would you post a picture of the truck so us poor folk can dream a little ! LOL
cheatham is offline
post #8 of 31 (permalink) Old 01-18-2011, 01:57 PM Thread Starter
yeah if I can get it to post up, you might of seen it before , it's been in all the ford magizines and was the 07 nmra champion.
post #9 of 31 (permalink) Old 01-19-2011, 01:39 AM
Send a message via AIM to mach1 Send a message via MSN to mach1 Send a message via Yahoo to mach1
what trans and conv were you running and what rearend gear if you dont mind telling me
mach1 is offline
post #10 of 31 (permalink) Old 01-19-2011, 08:37 AM Thread Starter
1.80 ptc glide with 10.5 inch converter and 4.10 rear , truck is set up for 1/4 mile not 1/8 but runs both pretty well , could be quicker in the 1/8 with a gear change, but have enough trouble trying to hook it with 4.10's on 29.5x10.5 's
post #11 of 31 (permalink) Old 01-24-2011, 09:15 AM Thread Starter
to the top
post #12 of 31 (permalink) Old 01-29-2011, 12:40 PM Thread Starter
come on guys someone needs this motor
post #13 of 31 (permalink) Old 02-07-2011, 04:20 PM Thread Starter
anyone
post #14 of 31 (permalink) Old 02-13-2011, 10:33 AM Thread Starter
bump
post #15 of 31 (permalink) Old 02-20-2011, 09:16 PM Thread Starter
bump
