Super clean 557 foxbody cage , - 460 Ford Forum
post #1 of 2 (permalink) Old 04-22-2012, 08:55 PM Thread Starter
Bam
Bam's Avatar
I just finished the build on the motor of this car motor is new 557 aluminum edelbrock performer 75 cc heads forged crank,forged pistons and rods,lunati cam soild flat and lifters,chromly trick flow push rods, canton 7 qt pan,million high volume oil pump, hay's flexplate, csr electric water pump, powder coated hooker headers. high tourqe power master starter, drag radials,xhaust, c4 trans,tci converter, pistol grip shifter ,all tachs and guges,cage could cert to 8.50 ,full spool 373 gears c-clip ends 31 spline moser
axles, 5 gal fuel cell, holley blue fuel pump, 750 hp carb,and much more to list call for more in for car has only 5 miles on build no corner cut on this build, and this is a 9sec street car all lights blinker work has painless with over head switch panel. call me if you would like more info to much to list. $11,000 obo5yellowfoxbody.jpg
Bam is offline
post #2 of 2 (permalink) Old 04-23-2012, 09:44 AM Thread Starter
Bam
Bam's Avatar
engine
i will sale the motor carb to pan $7,000. all you would need to do is tune it it's 11.5.1 compression
Bam is offline
