521 stroker kit, C9VE heads, victor intake - 460 Ford Forum
post #1 of 35 (permalink) Old 07-23-2012, 03:34 PM Thread Starter
Ok I got frustrated with trying to shoe horn this monster in my 69 mustang. so Im just keeping my cleveland. my loss is your gain. This is what I have.......
1. C9VE-A heads ported.
2. FRPP 521 storker kit using 4.3 crank, Eagle H beam rods, Forged SRP pistons part #150727
3. Ford motorsport VICTOR polished intake
4. Holley 1050 dominator carb
5. Stainlees steel CJ valves
6. Crane cams 1.7 RR part #13744-16 with guide plates
7. Boss 429 hood scoop 5" tall
pretty much everything except the Cam. If intrested make me an offer at [email protected]
wingman302 is offline
post #2 of 35 (permalink) Old 07-23-2012, 05:21 PM
521 Stroker Kit
How much for the 521 Stroker kit
73coupe is offline
post #3 of 35 (permalink) Old 07-23-2012, 08:02 PM
Scoop
Can I get a pic of the scoop
79Puller is offline
post #4 of 35 (permalink) Old 07-23-2012, 08:04 PM
Foxbigblock's Avatar
X2 and are they the 30 over dish?
1980 Mustang HB
429/C6
1989 Mustang notch
302/C4
Nate
Wide open til ya see God, then BRAKE!!!!
Foxbigblock is offline
post #5 of 35 (permalink) Old 07-23-2012, 08:19 PM Thread Starter
PM sent for Stroker kit
Pm me your email to send scoop pics.
post #6 of 35 (permalink) Old 07-24-2012, 08:08 AM
kjett's Avatar
Quoted: 17 Post(s)
FYI, the SRP 150727 pistons are 4.390 bore forged flat tops with a -3cc valve relief. It's spec'ed on the SRP site as a 501ci motor using 4.14 crank with a 6.8 rod and is 1.42 c/h. May want to check the part number again because the math won't add correctly for a 10.3 block with 4.3 stroke crank in any standard ford (6.605, 6.7, 6.8) rod configuration.
kjett is offline
post #7 of 35 (permalink) Old 07-24-2012, 10:47 AM Thread Starter
1. Deck height 10.3
2. Bore 4.390
3. Stroke 4.3
4. Rod length 6.605
5. CC using C9VE heads 72cc
6. Piston dome -3
7. Pin height 1.420
Equals>>>>>>>>>>
1. Deck clearance 0.125 inches
2. Compression ratio 10.4:1
3. Rod ratio 1.54:1
4. Max rod angle 19 degrees
5. Displacement 520.7
So yes I did my numbers and homework and have this set up!
post #8 of 35 (permalink) Old 07-24-2012, 11:04 AM Thread Starter
@Kjett believe me when I say this isn't my first engine build.
post #9 of 35 (permalink) Old 07-24-2012, 12:42 PM
kjett's Avatar
Quoted: 17 Post(s)
Never questioned your engine assembly skills. Just seems a bit low on the compression height than the FRPP 521 kit that Lem Evan's sells and will yield the same compression with a 28cc dish and a better compression height. Not sure you'd want to leave the piston .125 in the hole with a 10.3 deck height. Stock pistons were only .038ish in the hole with a 10.32ish deck height.
The original intent was to let others know what that piston p/n was originally for.
kjett is offline
post #10 of 35 (permalink) Old 07-24-2012, 01:39 PM Thread Starter
Reason for doing that is for more aggressive cam profiles and not worry about kissing the piston.
post #11 of 35 (permalink) Old 07-24-2012, 01:44 PM Thread Starter
@ kjett sorry wasn't trying to sound like a jerk.
post #12 of 35 (permalink) Old 07-24-2012, 06:24 PM
RmK57's Avatar
Quoted: 37 Post(s)
Shouldn't the compression height be 1.54 on those 521 Ford kits? Add up all the numbers and comes to 10.30. Maybe I'm wrong
RmK57 is offline
post #13 of 35 (permalink) Old 07-28-2012, 11:18 AM Thread Starter
pistons sold. thanks
still have 4.3 crank from ford racing and Eagle H beam rods 6.605.
make offers I need this stuff gone.
post #14 of 35 (permalink) Old 07-29-2012, 10:00 PM
69F100's Avatar
pm sent on rods
69F100 is offline
post #15 of 35 (permalink) Old 08-01-2012, 11:53 PM Thread Starter
Still for sale.....
