willys mud truck rolling - 460 Ford Forum
post #1 of 6 (permalink) Old 07-25-2012, 10:30 PM Thread Starter
48 Willys pickup 9 inch ford rear, mark williams axles, mark williams 3rd member with full spool. 4 link suspension, all 1350 driveshafts, chain drive transfer case, 39.5 cut boggers rear on beadlocks. New magna fuel 500 fuel pump and filter all new fuel line and fittings,new 5 gallon fuel cell, 2 brand new optima batteries and cables. New msd 7al-2 box, autometer gauges. New aluminum radiator, electric fan. Sweet rack and pinion, chromoly front axles,rear and front gears are richmond pro gears, aluminum hubs and rotors from racing in the dirt. wilwood dual master cylinder and calibers. J&W powerglide with aftermarket case all the best parts. Alan Pope performance stall converter. 3 passes on trans and converter. Set up for big block ford comes with headers. the front end is dana 44 with ford radius arms and coil springs. Has full roll cage and the bed and front clip is aluminum. truck hooks hard and is lightwieght.truck is all white now can text pics.call or text 309-224-4744 $13,500 obo
Whitebronco is offline
post #2 of 6 (permalink) Old 07-27-2012, 09:43 PM Thread Starter
$11,000 needs to go
post #3 of 6 (permalink) Old 07-29-2012, 05:39 PM Thread Starter
$9,000 or best offer
post #4 of 6 (permalink) Old 07-29-2012, 05:56 PM
Quoted: 175 Post(s)
There is a 3 day bump rule. If you want to change your price then edit the price in the original post. That way you don't keep bumping to the top. They may delete your post otherwise.
MrScharfenberger is offline
post #5 of 6 (permalink) Old 07-31-2012, 12:46 PM
460bronco's Avatar
What brand is the chain drive and how much did it weigh? Where are you located?
460bronco is offline
post #6 of 6 (permalink) Old 08-01-2012, 05:37 PM Thread Starter
sold
