Ford 429 Lima (Commercial) Steel Truck Crank - Pristine - 460 Ford Forum
post #1 of 12 (permalink) Old 09-08-2012, 06:53 PM Thread Starter
Paul Kane's Avatar
Quoted: 45 Post(s)
Cool Ford 429 Lima (Commercial) Steel Truck Crank - Pristine
CRANKSHAFT IS SOLD
FORD 429 COMMERCIAL TRUCK STEEL CRANKSHAFT
American forging, forged of american steel. In offset stroked form, these crankshafts have been known to support in excess of 2500 hp (not a garantee). This example is currently standard-standard on the mains and rods. All the journals are in such outstanding shape that they don't require so much as a polish. It can be offset stroked to a Ford 460's 3.85" stroke (possibly as high as 3.885") and still have a standard-sized 2.200" rod journal dimension (ie, the mains-rods of the crankshaft after stroking could still be std-std, depending on your needs). Or you might want to go 3.95" with a 2.100 journal (<---has greater journal overlap cross sectional area and cross sectional width than a 4.14" crankshaft's 2.200" rod journal). Straight out of the 429 Lima and never raced or abused.
  • 3.59" stroke
  • Standard main journals
  • Standard rod journals
  • unmodified 1.75" diameter snout and flange
  • Sell: $425
This crankshaft is the nicest untouched example of these cranks that I have seen. It is a personal item and being sold as such. Please note this is a sales thread, not a commentary thread. Serious inquries only, please. Better to call than to PM but I'll eventually answer PMs as well.
Thanks,
Paul
310-435-1900
CRANKSHAFT IS SOLD
High Flow Dynamics
Paul Kane is offline
post #2 of 12 (permalink) Old 09-08-2012, 08:08 PM
what is leinght on snout?
Richard is offline
post #3 of 12 (permalink) Old 09-08-2012, 10:00 PM Thread Starter
Paul Kane's Avatar
Quoted: 45 Post(s)
By tape measure, the snout length is 5 inches from the tip of the snout down to the thrust boss for the timing chain crank gear (same length as a passenger car 460 crankshaft). We have machined these snouts to 1.61" BBC, 1.53" Chrysler, and 1.375" BBF, all double-keyed.
Paul
High Flow Dynamics
post #4 of 12 (permalink) Old 09-14-2012, 04:28 PM
think I know the answer but does anyone make an ots 3.59 429 forged dish piston (1.040 pin) that would get me around 9-1 w/stock deck height and c8's uncut? seems everything is setup for 460 3.85
ifucan is offline
post #5 of 12 (permalink) Old 09-23-2012, 12:26 AM Thread Starter
Paul Kane's Avatar
Quoted: 45 Post(s)
Diamond has the #40201 460 piston with 25cc dish; see if they can move the pin down 0.125" (to the 429 pin location) and you'd have a 9:1 forged piston with a 75 cc head.
Paul
High Flow Dynamics
post #6 of 12 (permalink) Old 10-21-2012, 09:44 PM Thread Starter
Paul Kane's Avatar
Quoted: 45 Post(s)
I have a number of these steel crankshafts, from std-std (above) to various undersize combos, priced accordingly. Call directly to inquire.
Paul
High Flow Dynamics
post #7 of 12 (permalink) Old 01-29-2013, 08:15 PM Thread Starter
Paul Kane's Avatar
Quoted: 45 Post(s)
I have a number of these steel crankshafts, from std-std (pictured above) to various undersize combos, priced accordingly. Call directly to inquire.
Paul
High Flow Dynamics
post #8 of 12 (permalink) Old 01-30-2013, 12:15 AM
crank
do you have one thats .010 .010 or .010 .020 or .020 .020 that is a little cheaper? it has to be stock snout, thanks Butterbean and how much to be shipped to naples, Fl 34117 ???
butterbean is offline
post #9 of 12 (permalink) Old 01-31-2013, 01:26 PM Thread Starter
Paul Kane's Avatar
Quoted: 45 Post(s)
CRANKSHAFT IS SOLD
High Flow Dynamics
post #10 of 12 (permalink) Old 01-31-2013, 01:28 PM Thread Starter
Paul Kane's Avatar
Quoted: 45 Post(s)
Yes, we have a 0.010/0.010 crankshaft in stock, among others; call for details.
Paul
310-435-1900
High Flow Dynamics
post #11 of 12 (permalink) Old 03-25-2013, 01:12 AM
I noticed the 2,500 hp number. fully detailed one should be able to spin 8,000 or so?
Jon
http://i201.photobucket.com/albums/a...elake3-1-1.jpg
Going fast is only half the fun....what you make go fast is the other.
G-Code is offline
post #12 of 12 (permalink) Old 03-26-2013, 03:53 PM Thread Starter
Paul Kane's Avatar
Quoted: 45 Post(s)
Jon
8000 rpm: I know people who have run their offset stroked forged steel 429 truck crankshafts past 8000 rpm for years.
2500 hp: Currently, an engine is going together that will use our billet hemi heads and a 3.47" stroke, Chrysler rod journaled, 429 steel truck crankshaft. The engine is expected to generate more than 2500 hp...not that this is the example that serves for the 2500 hp number that I noted at the top of this thread (there have been other engines prior to this one).
Paul
High Flow Dynamics
