460 with c8ve heads - 460 Ford Forum
post #1 of 3 (permalink) Old 10-07-2012, 12:33 PM Thread Starter
gibs0n06's Avatar
460 with c8ve heads
i have for sale a 460 with c8ve heads block was hot tanked and new cam bearings installed. factory bore was still good nice cross hatches crank was turned .020/.020 with new speed pro performance main and rod bearings rods were reconditioned as well kept stock cast pistons re-ringed them with speed pro rings, fel-pro performance head gaskets. boutght the heaeds built with cam from a guy that had them on a 514 that he blew up heads checked out fine have ferrea 2.19 intake and 1.80 exhaust valves have screw in studs and push rod guides 1.70 roller rockers with hardened 5/16 pushrods have and offenhauser 360* dual port intake 1 carb spacer and holley 850 double pumper carb has a reed cam tm272h hydraulic flat tappet specs in a photo call or text 816-277-5136 thanks
1975 cj5 tub 1981 frame, hp dana 44ft , 14 bolt, custom leaf spring lift,?? bbf c6 and np205,with super swamper 38.5 boggers
gibs0n06 is offline
post #2 of 3 (permalink) Old 10-08-2012, 08:41 AM
is it free or did i miss the cost? If free i will take it :-)
majik455 is offline
post #3 of 3 (permalink) Old 10-08-2012, 05:53 PM Thread Starter
gibs0n06's Avatar
asking $1000
gibs0n06 is offline
