514 with p51 heads - 460 Ford Forum
post #1 of 1 (permalink) Old 10-24-2012, 05:51 PM Thread Starter
514 with p51 heads
Motor has 8 eighth mile passes went 6.0 at 115.5 mph in a 3100 lbs fox on drag radials and thru exhaust leaving at idle cause of the track conditions. but here it goes 1250hp dominator, ported vic jr, kassi p51 heads, comp roller rockers, ford racing valve covers,diamond pistons with around 13.6 comp, eagle rods and crank, comp cam solid roller around 725 lift, was built with a dive block but will have no issues holding the power for yrs to come the engine builder ran in the nmra for years and holds many records and is a ford god just wanting to build another motor for my 16yr old to run in my car, motor never dynoed but should be over 800hp im asking 7500 call or text john or might trade for a sd pickup
9050 is offline
