Wanted: Solid Roller Cam - 460 Ford Forum
post #1 of 3 (permalink) Old 02-21-2013, 01:27 AM Thread Starter
onequickstang's Avatar
Looking for a solid roller around .750 lift and 275 duration @50 in good condition for a drag racing engine. let me know what you have.
Thanks,
'68 Mustang Fastback. Coming soon - all aluminum 548 A441 Hemi! Gonna be one bad FoMoCo!
onequickstang is offline
post #2 of 3 (permalink) Old 02-21-2013, 09:49 AM
Cam
i have a custom comp roller double pinned for $225 Ray 816 332 0464
Serial # S 4158-10 Spec Card# 17543010
Part # 34-000-9 CAMSHAFT, FF FORD 429-460 ROLLER
Core C34-9A CAMSHAFT BLANK, FF FORD 429-460, 5160
Grind # FF 2233F /4075F SR112.0
DURATION @ .050 INTAKE 274 ROCKER ARM RATIO
VALVE ADJ INTAKE .016 DURATION @ .050 EXHAUST 289 INTAKE 1.73
VALVE ADJ EXHAUST .018 LOBE LIFT INTAKE .4550 EXHAUST 1.73
VALVE LIFT INTAKE .787 LOBE LIFT EXHAUST .4600
VALVE LIFT EXHAUST .795 LOBE SEPARATION 112.0
DURATION .020 INTAKE C/L 112.0
TAPPET LIFT INTAKE 303 CAM ADVANCE 0
TAPPET LIFT EXHAUST 323 HYDRAULIC
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 25 JOURNAL DIAMETER STD 2.124
VALVE OPEN EXHAUST 76 RECOMMENDED VALVE SPRINGS
VALVE CLOSED INTAKE 69 DEPARTMENT P
VALVE CLOSED EXHAUST 32 SPC INSTR FOR CUSTOMER
shelby_67 is offline
post #3 of 3 (permalink) Old 02-21-2013, 05:04 PM
roller cam
Cams & lifters for BBF
Ultra Dyne used
280 @50 740 lift intake [email protected] 740 lift exhaust execelent shape double pined $ 150
Crane 1 new 1 used
[email protected] 50 730 lift intake 286 @ 50 741 lift exhaust used $150 new $200
comp cam bought off site member New
[email protected] 50 796 intake [email protected] 50 726 exhaust $200
Isky 9945 Springs New
250 lbs at 2.02 875 @ 1.270 cb at 1.180 .750 lift 1.625 od $200
LUNATI SPRINGS New #74021
1.950 225 lbs 1.25 660 lbs cb @ 1.2 1.550 od $175
Lunati roller lifters ran 1 season
2 sets of 16 $200 a set
1 set of 6 pairs $100
All plus the ride
Denny 330 842 1886
Denny514 is offline
