90 lx 460/c4 f/s - 460 Ford Forum
post #1 of 3 (permalink) Old 07-09-2013, 02:11 PM Thread Starter
90 lx 460/c4 f/s
Ive had done 3 of these in the past...so bad times this needs to go....i try to be breif with this anthing at all u need to know just call or text me ..4432248395...first off...its a bored over 460..has edlelbrock rpm cam kit..ported heads weiand intake 850 holley dp.full msd ignition d&d mid length headers and i made the rest of the exhaust 3" into 2-1/2" h-pipe c4 trans with very thick bellhousing...manual valve body..3500 stall..b&m pro rachet shifter...car has new tires on ok pony wheels ..battery relocated to the trunk....cables all ran to the front all new fuel line has holley blue pump..now for the ..bad...car still has stock 4cyl rear and suspension....thats the only part i didnt change yet..car still needs minor work but it does run and can drive around the block due to needs fans ..i have 1 on it not wired up yet also needs electric waterpump motor drive wired..all easy minor stuff.....asking 3400.
starquest is offline
post #2 of 3 (permalink) Old 07-09-2013, 10:25 PM Thread Starter
3200..needs to go...asap
post #3 of 3 (permalink) Old 07-09-2013, 10:28 PM
BBFmavrick's Avatar
Pic's will probably help.
Rick Brown
Member of a BAND OF BROTHERS
Pro Motion Machining
Bronx Corner Automotive
BBFmavrick is offline
