NARROWED 9 INCH - 460 Ford Forum
post #1 of 1 (permalink) Old 01-07-2014, 10:53 AM Thread Starter
Gydyup's Avatar
Quoted: 31 Post(s)
NARROWED 9 INCH
9 inch housing, no axles, 49.5 flange to flange. Stock spring locators, so it will bolt up under a stock Mustang.
I had 28X9.5sX15 on 10 in rims under it, but did have to remove the rear end housing bumpers off the frame rails.
I shortened the axles again, so they are not going with it. When I mini tubbed mine, I figured someone could use this for a stock bolt in rear with more room since I was relocating my springs and shortening, I just completely cut another housing.
Housings are going for 290 and up on Ebay, Ill let this go for 175 and you pay shipping. I have the brakes for it as well, if you want those we can talk. Not sure I want to let those go yet, all new shoes, cylinders etc. I want Discs on the back, just coin is my hold up now.
PM me for pics or more measurments, but the only diff from stock rear on a 67 68 stang was the distance from the leaf pad to the flange. The location for drive shaft & pinion angle etc is all factory.
Gydup -67 Coupe, 521 Kaase P51 Comp Solid Roller . Jerico DR4, narrowed & mini tubbed 9 inch with 4:56 spool , Mark Williams Axles on CALTRACS, Shaved towers.
"Owner built-owner abused, if it was easy everyone could have a car like this"
Real cars have three pedals.
Gydyup is offline
