ISO of #1 Main CAP - 460 Ford Forum
post #1 of 8 (permalink) Old 02-08-2015, 06:39 PM Thread Starter
TOPHER1's Avatar
ISO of #1 Main CAP
All I am looking for Number 1 main cap. It appears that after breaking my 504's crank it may have damaged #1 main cap. Does anyone have any extras floating around that I can purchase so I can the block line bore fixed
Chris
TOPHER1 is offline
post #2 of 8 (permalink) Old 02-08-2015, 07:52 PM
Quoted: 193 Post(s)
Chris
I might have which block are you using?
give me a call tomorrow
BUY,SELL, or TRADE BBF parts
Dynoed or Test STAND RAN
CYLINDER HEAD PORTING
HEAD FLOWING
PRO SYSTEMS CARBS
BOSS 302 351 429 800CI+
BOSS 429 is offline
post #3 of 8 (permalink) Old 02-08-2015, 08:05 PM Thread Starter
TOPHER1's Avatar
Block
I am running D9TE-AB if that helps
TOPHER1 is offline
post #4 of 8 (permalink) Old 02-09-2015, 08:41 AM
WHAT CRANK IS THAT...? was that " cheek" ground on for balancing..?
torino501 is offline
post #5 of 8 (permalink) Old 02-09-2015, 11:08 AM Thread Starter
TOPHER1's Avatar
Block
torino501 that was an eagle 4.14 cast stroker crank. Does not appear to be ground on in the cheek area to balance but not sure because I purchased the short block used and yes I had it gone through and balanced before running. Ran 9.26 at 146 MPH and 5.84 at 117MPH in 2800# car with driver not bad for a flat topped 10 to 1 pump gas motor.
Was told when purchased it only had 25 passed on it but I am assuming it about 5000 road miles and 25 very hard Nitrous passes on it because when it received the bearing had copper showing. So any way I put about 300 passes on it before letting go and the only damage thus far is number one main cap is sitting loose in the saddle that is why I am looking for main cap to have line bore checked/repaired.
Chris
TOPHER1 is offline
post #6 of 8 (permalink) Old 02-10-2015, 09:31 AM
575ciBronco's Avatar
I have one if you want to pay for shipping I can send it to you I will send the whole set if you want em.
Derrick
575ciBronco is offline
post #7 of 8 (permalink) Old 02-11-2015, 03:41 PM Thread Starter
TOPHER1's Avatar
ISO #1 cap
575ciBronco PM sent.
TOPHER1 is offline
post #8 of 8 (permalink) Old 02-13-2015, 10:53 AM Thread Starter
TOPHER1's Avatar
THANKS TO ALL
Cap is on its way. Thanks to all that responded.
TOPHER1 is offline
