For Sale Carb to Oil pan turn key 514 - 460 Ford Forum
post #1 of 2 (permalink) Old 03-03-2015, 10:06 AM Thread Starter
575ciBronco's Avatar
Selling for a friend of mine. I'm sure I will forget some details so just message me with any questions.
-DIVE BLOCK
-SCAT FORGED 4.15 STROKE CRANK
-SCAT H-BEAM RODS
-SRP FLAT TOP PISTONS 4.44 BORE
-MAIN GIRDLE AND STUDS
-CLEVITE ROD AND MAIN BEARINGS
-MAHLE FILE FIT LOW TENSION RINGS
-CUSTOM GROUND COMP CAM SOLID ROLLER .761/.761 LIFT 276/286 DURATION @ .050 ON 112LSA (DOUBLE PINNED)
-MOROSO REAR SUMP OIL PAN
-ROLLER CAM BEARINGS IN BLOCK
-BUSHED LIFTER BORE
-MOREL LIFTERS
-HARLAND SHARP 1:73 ROCKER ARMS
-DOVE-C HEADS MILD PORTING CJ SIZE VALVES
-FORD RACING VALVE COVERS
-VICTOR 460 INTAKE
-1250 HOLLEY DOMINATOR
I'm sure i forgot to list something but message me for details. Engine is located in Clarinda ,Iowa it is still in the truck you can hear it run. It was fresh last winter and has around 40-50 passes in a mud truck. Asking 5,000 obo he has a new engine getting built right now and wants this one gone. He said he would assume just keep his MSD distributor but could work a deal out on it as well if the buyer wants it.
Thanks Derrick
575ciBronco is offline
post #2 of 2 (permalink) Old 03-09-2015, 11:13 AM Thread Starter
I forgot to put the compression this engine is 15:1 we ran it on VP X16.
Derrick
