1973 Montego (rust free CA car) - 460 Ford Forum
post #1 of 1 (permalink) Old 05-01-2018, 04:25 AM Thread Starter
I would sell as ROLLER so u can put your 460 in it...
Car is in Northern Michigan
Email [email protected]
Email for pictures and questions
Car info below.....
1973 Montego 351 RAM AIR (OLD BRACKET DRAG CAR).....
Turn key, race as is....or can be put back on street...or easy restoration project car.....
100% Rust free California car, NO RUST EVER, never seen winter (only been in Michigan for 2 years and always garaged) also has the factory paint dabs, chalk marks on undercarriage and original gold paint still on floor pans...........car has had 1 repaint back in the 80's in original color....but its faded and chipping off....
FRESH REBUILT..... STOCK 351 2V cleveland.....
original standard size dished pistons and Sealed Power rings, Sealed Power .010 main, .010 rod and cam bearings, ARP rod and main bolts, reproduction Cobra Jet cam, nos Cobra Jet valve springs, Comp Cam 10 valve spring retainers and keepers, valve job, roller timing chain, Sealed Power oil pump, Cobra Jet oil pan, new harmonic balancer, new water and fuel pumps, carb kit, Fel Pro gaskets, pertronix in distributor and pertronix coil...new plug wires..... Also..I did not paint the motor...left it original paint...so it matches the look of the car.....ALSO...the motor only has 1 weekend of racing after rebuild......
New: Hooker Comp Headers....(NO exhaust system)
New: radiator, hoses, belt and battery.....
Factory Ford Ram Air Hood with Reproduction steel RAM AIR Plenum and aircleaner...... (I have original flat hood and aircleaner)
Rebuilt: c4 trans with B+M trans kit.....
Rebuilt: 3.50 mini spool 9" rear end.....
New: brakes, steering wheel, tach and gauges, and alot more.....
Heater and a/c deleted...(I do NOT have them)
Manual steering..... (I have PS system)
Light weight front bumper brackets, they took 95lbs off front end........(I have originals)
It has 14x6 Magnum 500's on the front and 14x7 on back...also comes with stock steel wheels, hub caps and tires.... Now has black steel wheels and slicks on the back.... Also comes with a pair of cheater slicks from the 70's on black steel wheels...(cool to hang on wall)
Turn key strip/street car.....raced 6 days summer of 2016 and won 3 times and 1/4 finals 2 other times....won $750....summer of 2017 got 1 runner up finish....fastest run so far 15.20 at 88 mph...with a set of 4.11 gears it should run 14.90 at 90.....not bad for 2 barrel carb cleveland....
I have a Motorcraft 4v carb that comes with the car, just buy a 4v intake and the car should then run low 14's....
****COULD EASILY BE PUT BACK ON THE STREET****
!!!!!!!! Comes with MORE then a truck load of extra parts that u can sell off to recoup some of your money (list below)...also comes with a CRACK FREE dash pad......
Also have Marti Report and there was 2,800 built in this color combo......
The Paint, Vynil Top and Complere original Interior have california SUN DAMAGE ....nice patina for a old drag car...and there is acouple dents in body...
$6500 OR BEST OFFER Cash for car and parts...
Would sell without any of the following: Extra Parts, Ram Air Hood, Magnum wheels and tires, slicks, and manual steering box....
Would also sell as a ROLLER without drivetrain....
Might also take partial trade and cash if u have something like.....77-79 Cougar or LTD II or 76-78 Cobra II....
PARTS LIST INCLUDED WITH CAR:
(Original parts taken off the car)
2.75 gears
Spider gears
Front sway bar
Frame frame braces
Inner front crash bumper and brackets
Exhaust manifolds and heat shield
Power steering system and correct Pulleys
Bumper jack
Wiper system
Trans kick down rod
3 spoke rim blow steering wheel
(4) 14x6 steel wheels, tires and hub caps
Flat hood
Original aircleaner and air tubes
Original radiator
And probably more small stuff
(Extra 72-76 parts)
72-79 dash pad (no cracks)
72 Motorcraft 4v carb off 460
(2) 73 2v carbs
Misc. 351c parts
(4) 14x7 Painted Magnum wheels with new BFGs
(7) wide trim rings for the Magnums
(2) 14x6 Painted Magnum wheels with new BFGs (no trim rings)
(2) 15x6 black steel wheels with new Hoosier slicks
(2) 14x6 black steel wheels with 1970s cheater slicks (cool wall hangers)
(2) 14x6 black steel wheels (no tires)
MERCURYCOUGARS is offline
