For Sale 700+ HP 502 with P51 Heads - MI - 460 Ford Forum
post #1 of 2 (permalink) Old 10-05-2018, 12:42 PM Thread Starter
Pitcher's Avatar
Engine was built and June of 17 and has less that 2 Hours of total run time most of that is warm up time. The truck didn't run much due to Transmission failures.
It was Dyno'd 10/3/18 Made 737HP and 618TQ
Here is a video of it running. https://photos.app.goo.gl/h3fiqLG3LRmoxLxZA
D0VE block All ARP studs and bolts
Scat Forged Crank and H beam rods, SRP Forged pistons and Main Girdle
12.5:1 Compression.
.787 Lift Solid roller Comp Cam, Crane Gold roller rockers, with Rocker Girdle
Kaase P51 heads and Trick Flow R-Series
Ron's Terminator Alcohol injection kit.
Complete engine minus water pump. (it's remote mounted in the chassis). $10K
With a Prosystems 1050 E85 Carb $9000
Located in SE Michigan but will can ship it anywhere in the US pretty inexpensively.
Pitcher is offline
post #2 of 2 (permalink) Old 11-29-2018, 09:41 AM
Would you be will to part with the P51 Heads?
Michael Rastocky is offline
