For Sale 429/460 old school stroker rods $79.95 - 460 Ford Forum
 1Likes
  • 1 Post By CarsByCarl
post #1 of 1 (permalink) Old 02-05-2019, 02:48 PM Thread Starter
CarsByCarl's Avatar
Quoted: 186 Post(s)
C8AE-A Connecting rods
Remanufactured
2.123 journal
.975 pin
6.795 length (factory spec. actual length is likely to be slightly shorter or longer)
Press fit pin
AMS 6415 steel, which is aircraft grade 4340
This is a set of eight 240 Ford six cylinder rods. They were frequently used back in the day to build stroker motors before aftermarket rods were more commonly available. We have built several engines with them by opening up the pin to .990, using an off the shelf 429/460 stroker piston with a 1.42 compression distance, and offset grinding a 460 crank to a 4.200 stroke. Displacement ranged from 509 to 520 cubic inches depending on overbore.
This is a great way to build an all American engine on a moderate budget. All you need are American made pistons, rings, and bearings, and to have your local machine shop offset grind the crank.
A knowledge of custom engine building, and custom machine work is required when using these rods in the application described. Please be sure of what you are buying.
PAYPAL ONLY
1EFF100 likes this.
CarsByCarl is offline
For Sale Old school C8AE-A stroker rods CarsByCarl The Auction Block 0 07-19-2018 03:56 PM
4.250 old school stroker crank FastAshley The Auction Block 0 08-10-2012 02:42 PM
Mechanics way of catching women old school! 747JETMECH Chilly's Garage 1 08-14-2007 06:37 PM
Old school drag racing freak78 Chilly's Garage 11 02-03-2007 07:32 AM
Old School TRW 429 Flat Top-to-460 Flat top Conversion UPDAT chilly Engine Tech Archive 0 01-24-2006 03:20 PM
