532 Engine Parts Package (New) - 460 Ford Forum
post #1 of 5 (permalink) Old 02-15-2006, 12:14 AM Thread Starter
Engine parts will be sold as a package: New Kaase/SCJ aluminum heads complete with CNC porting by MPG, new Harland Sharp roller rockers, new 4.440 bore dished BRC pistons, new 6.800 Eagle rods, new 4.300 stroke Scat cast steel crank, new a/t flywheel, rotating assembly has been balanced, new Total Seal file fit rings, new Clevite rod and main bearings, new rocker studs, new guide plates, new push rods, new Cam Research 588/614 hyd. camshaft and lifters. prepped DOVE-A wide web two bolt main 70 CJ block, new main stud girdle. I'm listening to offers right now. If you are interested let me know. I can be contacted directly at-> [email protected] Thanks Jim
ford632 is offline
post #2 of 5 (permalink) Old 02-28-2006, 09:04 PM
rvesterby's Avatar
Still For sale ??
Is it still for sale as a package ?
rvesterby is offline
post #3 of 5 (permalink) Old 03-01-2006, 07:01 AM
Gearhead559's Avatar
A or B scj heads?
The heartbeat stops here!
www.gearheadzautomotive.com
Gearhead559 is offline
post #4 of 5 (permalink) Old 03-01-2006, 11:07 AM
Paul Kane's Avatar
Quoted: 45 Post(s)
Re: 532 Engine Parts Package (New)
Originally Posted by ford632
new 4.440 bore dished BRC pistons, new 6.800 Eagle rods, new 4.300 stroke Scat cast steel crank, new a/t flywheel, rotating assembly has been balanced, new Total Seal file fit rings, new Clevite rod and main bearings. Thanks Jim
Jim, I understand that you don't wish to break up the motor. If you should later decide to do so, then I might be very interested in the 533 rotating assembly complete. PM me if you decide to do so.
Thanks,
Paul
High Flow Dynamics
Paul Kane is offline
post #5 of 5 (permalink) Old 03-03-2006, 04:24 PM Thread Starter
Out Of Town
Sorry I haven't been able to answer replies about the 532 package that I posted. I am presently in Colorado and have limited interenet access to check messages on a regular basis. I will be back March 16th, if you are still interested please contact me then. Thanks Jim
ford632 is offline
engine and parts for sale--parting out pulling tractor LETHAL_DOSE The Auction Block 6 03-08-2009 04:19 PM
BBF Engine and misc. parts. joemcfee The Auction Block 7 08-07-2008 11:50 AM
532 engine build info track proven 1/4 mile 65gal Engine Build Archive 10 12-05-2007 09:33 PM
iron head tech talk bigbob Engine Tech 8 10-13-2006 11:55 PM
CYLINDER HEAD INFO chilly Engine Build Archive 10 01-24-2006 03:30 PM
