Looking to buy a C- headed big block to run 5.90's 1/8 mile - 460 Ford Forum
post #1 of 7 (permalink) Old 04-13-2006, 09:03 PM Thread Starter
I am looking for a c- headed big block to run 5.90's or alittle faster in the 1/8 mile in a 2950 lb mustang thats well set up with cal tracs, monoleaf springs, 10 point cage 28 x 10.5 "s" slicks ect.
If you have something in the texas area please call 979-251-8992 and leave message or e-mail me at [email protected]
I have dual rons toilets that I would like to put on a tunnnelram and run alcohol on the motor and C-4 trans. prefer something running in good shape and not needing rebuild right away.
I have score to settle with a couple of so called freinds with "chevy" motors a 540 and 572 motor both running 5.90's on 10 inch tires.
any help would be appreciated.
thanks
Mike S
Help I need a bigger motor
seefour is offline
post #2 of 7 (permalink) Old 04-14-2006, 12:29 AM
I would think that any motor with C-heads would destroy 5.90s easy
Chris is offline
post #3 of 7 (permalink) Old 04-14-2006, 05:33 PM
What engine are you using now? I agree that any respectable BBF with C heads would be overkill for 5.90's. We use a 9.8 to 1 compression 514 with alum. CJ's to go 5.80's at 2700 lbs. I think you could do this cheaper and embarrass the Bowtie guys even more. Nothing gets them pissier than to have their GMPP 572 dusted off by a hotrod Lincoln motor with a cheap stroker kit.
Maverick is offline
post #4 of 7 (permalink) Old 04-15-2006, 12:30 AM Thread Starter
Well thats the problem
I have a motor in the machine shop at the moment, The deal is my machinist is slow...but "GOOD"!
Its a stroker small block 410 cubes
Dart block .040 over
4.0 stroke 4340
6.0 4340 rods h-beam
solid roller .775-.757 266-273 @.050
CHI cleveland style heads 218 cc runner 340-240 @.8 flowed on 4.0 bore and runners cc'd at shop
CHI single plane with rons toilet 1435 cfm on methonal
13.2 compression
4800 stall
caltracs w mono leaf springs , 10 point cage , subframe connerctors
C-4 "built"
4.33's 28 x 10.5 "s" slick
2850 lbs
the motor is brand new havent run it yet ,but getting antsy, havent made a pass since sep 2004
MMM
seefour is offline
post #5 of 7 (permalink) Old 04-15-2006, 09:12 AM
Just a thought, but if you haven't tried that combo yet, you might be surprised. We've got a steel Falcon down here that runs 5.50's with a 401" alum Windsor & spray. It's on 10.5's and weighs over 3000 lbs.
This is only my guess, but your car may run high 5's with a glide/brake, 5500 converter and short gears. Clevelands like to spin, and I've seen lots of them run 5's. when allowed to rev. If I had a "572 Whicheverway" that lost to that SBF, I'd have to:
1. Shoot my engine builder
2. Switch brands
or 3. Choose a different hobby
Maverick is offline
post #6 of 7 (permalink) Old 04-15-2006, 09:16 AM
P.S. Can you shave a little weight? That's usually gets e.t. gains much cheaper than more "go fast parts".
Maverick is offline
post #7 of 7 (permalink) Old 04-16-2006, 11:09 AM Thread Starter
thanks.
Ive got the C-4 wich im gonna stay with for now.
The converter is a 4800 stall but with the injection I think it will flash 5000-5200. with the weight? lexan front windshield and back glass and fiberglass trunklid is what would be left. Ive gutted the doors and the $ per puond of weight ,to me is not worth it.
Ive found a motorsport headed big block but after comparing the cost with what Ive already spent I think Im just gonna hold out till the small block is ready. Maybe it will be enough to handle the job.
Mike S
seefour is offline
BLOCK INFO (revised 11/20/07) DJOHAGIN Engine Build Archive 12 03-25-2010 05:01 PM
2007 Big Block Ford Bash Racing and Tech DVD Phantasea466 The Auction Block 85 10-20-2009 10:11 AM
WE CAN NOW RUN A PROCHARGER ON A BIG BLOCK FORD FDPOWER Engine Tech 67 01-18-2008 09:16 AM
Block Summit Info chilly Engine Tech Archive 0 01-24-2006 10:01 AM
Main Girdle results chilly Engine Tech Archive 0 01-17-2006 10:26 AM
