64 Galaxie big block - Page 2 - 460 Ford Forum
 5Likes
post #16 of 23 (permalink) Old 07-29-2019, 12:36 PM Thread Starter
Quoted: 7 Post(s)
Originally Posted by wickettoby1 View Post
Are the pictures decieving or is the mustang 2 setup quite a bit narrower than the stock Galaxie frame?
The insides of the Galaxie framerails is about the same as what I have built here. The outsides is quite a bit wider. I think the Galaxie rail is like 3”x5”. The sections of rail I used is 2x5.
DAMAGEinc
nedceifus is offline
post #17 of 23 (permalink) Old 07-29-2019, 12:40 PM Thread Starter
Quoted: 7 Post(s)
Burned it in & trimmed 104lbs of weight. I’ll have to add a hoop to support the radiator support but it will be substantially lighter. That & it will get a glass core support, bumper, fenders & hood, no inner fenders.
File Type: jpg 265E274B-9596-4741-B41B-5A6A4946335A_1564421945081.jpg (13.6 KB, 8 views)
File Type: jpg 0683ABAA-3421-46BB-B5B2-CF486AAD053C_1564421978166.jpg (15.3 KB, 9 views)
File Type: jpg 0846286F-A628-4396-8030-22CC7D76DA5F_1564421991923.jpg (15.6 KB, 10 views)
File Type: jpg 613701A6-6198-40B6-B05E-44CD2B1AD910_1564422016118.jpg (19.9 KB, 9 views)
File Type: jpg 8FCFE8C2-B6BF-4F97-A782-090E135A90EA_1564422049918.jpg (17.0 KB, 8 views)
DAMAGEinc
post #18 of 23 (permalink) Old 07-29-2019, 06:31 PM
Quoted: 20 Post(s)
Nice job,104 lbs is a nice chunk, that should be good for a 1/10th plus the better weight transfer.
Mike R is offline
post #19 of 23 (permalink) Old 07-30-2019, 09:12 AM Thread Starter
Quoted: 7 Post(s)
I have to drop as much weight as possible, Mustang 2 components are not really built for a car this heavy with a big block. Next up is aluminum heads & unfortunately they will probably be ProComps. This is a temporary motor so I am not going to dump a ton of cash into it. Right now my funds need to go to fiberglass & supporting equipment.
DAMAGEinc
post #20 of 23 (permalink) Old 07-30-2019, 05:59 PM
Quoted: 20 Post(s)
I wouldn't bother with the procraps, they're junk out of the box and by the time you have them built with good parts and machine work they're still no better than a set of worked D3's. You should be able to find a good set of used aluminum heads if you look hard enough, there's always a couple of sets for sale in the big block Facebook groups and you could post an ad on BIG BLOCK FORD'S there's a lot more traffic over there. If you want a list of the Facebook groups shoot me a PM and I'll hook you up.
jeffgfg likes this.
Mike R is offline
post #21 of 23 (permalink) Old 08-02-2019, 02:44 PM Thread Starter
Quoted: 7 Post(s)
Man I need aluminum heads!!!
File Type: jpg BFF64ED8-2461-43A8-86AE-68E87896C2B9_1564775057804.jpg (16.2 KB, 6 views)
DAMAGEinc
post #22 of 23 (permalink) Old 08-02-2019, 04:39 PM
I have a set of unused ProComp heads fully assembled. I ended up going a different direction; $750 shipped.
Shawn Schroeder is offline
post #23 of 23 (permalink) Old 08-02-2019, 08:37 PM
Quoted: 20 Post(s)
Did you check out those TFS 290's on face book? They looked like a good deal
Mike R is offline
