67 Galaxie 460 swap - Page 2 - 460 Ford Forum
post #16 of 18 (permalink) Old 01-19-2019, 03:40 PM Thread Starter
DCapps's Avatar
Ran the fuel line and wiring for fuel pump and sending unit down the frame today.
Also mocking up the filters, pump and regulator. I mounted them on a 5”x24” piece of 1/4” aluminum. The plate will be bolted to some studs that I will weld onto the tank straps, that way it’s tucked away nicely, and below the fuel as recommended. Used Holley’s filter regulator so I don’t have to run a return from the engine back. Now it is right at the tank, Return will be about 16” long. I will be welding a -6 male flare into the lower portion of the tank for the pickup. I will be repurposing the original pickup tube as the return with a 3/8 compression fitting to a -6 AN male flare.
File Type: jpg 5AA2D7F7-4ABD-4639-9224-2E0A356B462F_1547933815216.jpg (18.1 KB, 9 views)
File Type: jpg 1AA76682-9F3A-498E-BE6E-A7BA6FFD807E_1547933827254.jpg (20.3 KB, 9 views)
File Type: jpg F1FECE46-8828-46B5-B2EE-9755163D3A01_1547933842187.jpg (17.4 KB, 11 views)
File Type: jpg B20E1070-8B4F-4D7A-9DA9-A8952F70FA71_1547933853654.jpg (14.9 KB, 11 views)
DCapps is offline
post #17 of 18 (permalink) Old 01-21-2019, 09:28 AM
Quoted: 175 Post(s)
Looks great so far! A true frame off restoration. I'll be following your progress. I love the old Galaxies but I think the 66 & 67 Fairlanes are my favorite. Keep at it. Nice job!!
Send Questions To: Chri[email protected]
MrScharfenberger is offline
post #18 of 18 (permalink) Old 01-23-2019, 04:45 PM Thread Starter
DCapps's Avatar
Thanks, biggest hurdle I just ran into was realizing the factory ac wasnt going to fit, so now it’s time to fit a vintage air system in. Removed the plug wire brackets off the valve covers that i’m not using, and covered with some door plate badges. I like the way that turned out. More to come.
File Type: jpg 120ECB3E-4735-469C-B67C-69CD1F7E1859_1548283195938.jpg (19.7 KB, 10 views)
File Type: jpg 62EA7078-B878-4E0A-8FD4-57698771ABF0_1548283276629.jpg (14.7 KB, 10 views)
DCapps is offline
