75 f100 495 twin turbo dd - 460 Ford Forum
post #1 of 5 (permalink) Old 07-21-2019, 08:46 PM Thread Starter
Quoted: 9 Post(s)
Fixing to start a new project for a friend 75 f100 street truck with daily driving capabilities with a little extra go when needed. Wanted no less than 10mpg, pump gas, good handling , a.c. and some go, we came up with a 495 twin turbo with e4od trans. Here's a couple pics of truck as it is now.
Steve/oh is online now
post #2 of 5 (permalink) Old 07-21-2019, 09:02 PM Thread Starter
Quoted: 9 Post(s)
Some specs on the engine, a460 block, 4.150 scat forged crank, scat h beam rods, racetech pistons, afr 295 heads with .25 raised ports, afr intake, comp ultra mag rockers, comp roller lifters, forgot cam specs. Engine is 9:1 for pump fuel hope fully efficient enough to pull the mileage, going to run twin ls series 7675 precision turbos 8-10 pounds should put us around 1000hp, after all the plumbing is done will be headed to dyno. Will be using a fitech 1200 hp system , looking forward to seeing how this works.
post #3 of 5 (permalink) Old 07-22-2019, 09:54 PM
Quoted: 10 Post(s)
Unless you already have the heads why would you choose to use the AFR 295ís over the 315ís?
wickettoby1 is offline
post #4 of 5 (permalink) Old 07-23-2019, 09:05 PM Thread Starter
Quoted: 9 Post(s)
Not trying to make as much power as possible, wanted a efficient engine that would make good power and not turning it hard, mileage was the biggest concern with this build, smallest displacement possible was what we wanted, 270s would of fit the build but if he wants to grow down the road he's got room to.
post #5 of 5 (permalink) Old 07-23-2019, 09:07 PM Thread Starter
Quoted: 9 Post(s)
Going to dyno on just the engine and see what it does in the next few weeks.
