3500 stall converter and road driving - 460 Ford Forum
post #1 of 2 (permalink) Old 04-28-2019, 09:17 PM Thread Starter
New to the forum here. I have a 1979 250 with a turbocharged 460. It has a c6 trans and with a 3500 stall converter and a B&M trans pack. First gear works fine but when going down the highway at 55 i noticed it seems like I have to keep giving it more throttle to keep going. When I give it throttle rapidly i can feel a slipping like vibration going on. I want to rebuild the tranny to freshen it up but was wondering if that high stall converter will cause this issue again or are the clutches just bad. I also noticed small metallic flakes on the dip stick when I checked the fluid level. Any help would be appreciated. Thanks
1979_F100 is offline
post #2 of 2 (permalink) Old 04-29-2019, 03:55 AM
Quoted: 44 Post(s)
Sounds like you might have a bit more going on than just the torque converter.. Really need to get inside the trans and see what is going on..
As for converter , have is cut open and rebuilt by a reputable converter company. It would depend on what the converter was in the first place, was it specifically built for your motor ? Or and off the shelf generic? If the 2nd one then is your motor + turbo making good torque and blowing through the converter (As in making more torque than converter was designed to handle , hence = slip)
gregaust is offline
TCI 3500 stall c4 or c6 anti balloon converter postaldan The Auction Block 0 03-12-2011 06:51 AM
WTB ford c6 3500 stall converter joe4g63 The Auction Block 0 06-20-2010 06:31 PM
Dacco 3500 stall converter finch The Auction Block 0 11-19-2009 07:30 PM
Driving with Stall converter 66460GAL General Tech 8 10-13-2007 02:15 PM
Torque Converter f/s or Trade - 3500 stall for C6 Mach1steve The Auction Block 0 08-21-2006 08:13 PM
