1995 mustang rearend in a 1984 mustang - 460 Ford Forum
post #1 of 7 (permalink) Old 03-03-2010, 06:42 PM Thread Starter
Will an 8.8 out of a 1995 mustang work in a 1984 mustang?
tiger is offline
post #2 of 7 (permalink) Old 03-03-2010, 09:38 PM
Thumbs up
Should work but the 95 Mustangs rearends are 3/4" wider on each side than the 79-93 Mustangs IIRC.
Later Mark.
Mark Miller is offline
post #3 of 7 (permalink) Old 03-03-2010, 10:32 PM Thread Starter
Thanks Mark
tiger is offline
post #4 of 7 (permalink) Old 03-04-2010, 10:09 PM
No Problem,Later Mark.
post #5 of 7 (permalink) Old 03-10-2010, 08:01 PM
the rear end are the same lenght..its the axles that are longer cause of the disk brakes
johndickjr is offline
post #6 of 7 (permalink) Old 03-13-2010, 12:37 PM
Send a message via MSN to Blackcoupe
You will still be fine with wheel selection, just add the extra width into the equation when you are figuring out backspacing. IIRC you'll need one different fitting on the back and you might want to grab the master cylinder(I think the booster is smaller, it's been a long time since I've done that swap but I did on a 20th anniv car I had) and porportioning valve out of the same car if you can.
Jr.
87 coupe 306 5spd
85gt 466/c-6 sold
85gt new project
69 4x4 460/4spd
Blackcoupe is offline
post #7 of 7 (permalink) Old 06-09-2010, 10:16 PM
That's exactly what I have in mine.......... no problems..
5plates is offline
