83 ranger with no traction - 460 Ford Forum
post #1 of 9 (permalink) Old 01-21-2011, 04:47 PM Thread Starter
Hi i have an 83 ranger with a fairly built 460 and c6 with 3000 stall. im having a huge issue with getting traction. Right now it has an 8.8 with leaf springs traction bars and air shocks (not the best setup lol), i was wondering if anyone had some good ideas about going with a new setup such as a 4 link? I dont have much suspension experiance so any info will help. thank you
big bock ranger is offline
post #2 of 9 (permalink) Old 01-21-2011, 05:28 PM
bigblok86ranger's Avatar
Quoted: 16 Post(s)
I went with Ladderbars and coil-overs on my 86 and was the best option as far as I am concerned.
Eric Millard
[email protected]
528ci of N/A power
Circle R Racing Engines
Trick Chassis
Beloit,WI 53511
608-313-9197
http://www.trickchassis.com/
bigblok86ranger is offline
post #3 of 9 (permalink) Old 01-21-2011, 05:33 PM Thread Starter
ok thanks for the reply, do you know of any kits or a good brand to use?
Big Block Ranger
post #4 of 9 (permalink) Old 01-21-2011, 06:11 PM
Quoted: 16 Post(s)
I used all Competition Engineering the price is fair and quality isn't too shabby either. I even used there coil-over kit, its not the most high tech stuff but it works.
Eric Millard
[email protected]
528ci of N/A power
Trick Chassis
Beloit,WI 53511
608-313-9197
post #5 of 9 (permalink) Old 02-08-2011, 07:41 PM
I used a Ladder Bar kit from S and W race cars, it is designed specifically for the Ranger. Heres a link to there website. http://www.swracecars.com/Files/CATpg32.pdf
I have 31x14.5 M/T Et Street Tires on my truck that helps with traction.
Is your firewall stock or has it been modified for more engine set back? How modified is the engine?
501ranger is offline
post #6 of 9 (permalink) Old 02-08-2011, 07:46 PM
mount a 100lb piece of lead on the inside of tailgate.
gafred99 is offline
post #7 of 9 (permalink) Old 02-17-2011, 10:39 AM
i dont have a range but i did have 60 ft trouble i went with a home made cal trac style traction bar with the rancho 9 way shocks turn my truck into a ball buster on launch for the engine i have 1.50 to 1.55 60ft for a 3870lbs there is alot 2 do with tire pressure 2 hoosier dr i ran at 12psi mt dr 14psi dont be afraid 2 lower it down and play with it measure front end travel you want 5" of travel sitting with you in it then measure your fender opening then jack it up till the wheel is just off need 5" take a video of your launch make sure both are spinning if using a posi try hitting the tire harder or softer leaf springs can work very well
dragweek quickest street rod
2009 2010
quick 52 is offline
post #8 of 9 (permalink) Old 02-21-2011, 01:11 PM
557BBF's Avatar
I dont have a big block in my 90 ranger, but I do have a 450hp 2.3L turbo, and I used 3800lb Mopar Super Stock rear springs that are for a 426 hemi Cuda and they work amazingly well. Ride great, handle great, and dont have any lift or traction bars. The front half is 20" long and the rear is 36" which means you have to move the front hangers down and back and the shackles back. They are also setup for spring under axle, but Im using an Expo 8.8 with disc brakes, and they are an spring under setup so it is all good. Oh they are a left and right set. The right side has 6 full leaves and 2 half leaves facing forward and the left has just 6 full leaves. This counteracts the natural torque twist of any engine and they come with the front halves clmped already.
Real cars dont have hood props.
1971 Mach1 --- the last year of Ford muscle
557BBF is offline
post #9 of 9 (permalink) Old 03-16-2011, 09:10 PM
mine is for sale, hard part al done!
http://nwct.craigslist.org/cto/2267333234.html
I was getting 1.2 60ft times with the front wheels off the ground with a relatively mild small block. Truck weighs 2600 # 4-link.
R8NGER is offline
