What RPM for Shift Light - 460 Ford Forum
post #1 of 5 (permalink) Old 06-21-2012, 06:03 PM Thread Starter
At what RPM should I be shifting?
460 d3 block and heads, .545 lift cam, stock rebuilt bottom end, edelbrock performer intake with edelbrock 750 carb, 9.5:1 compression, 3.54 gears, 28/10.50-15 slicks
dpoepperling is offline
post #2 of 5 (permalink) Old 06-21-2012, 08:57 PM
TRUKPULR's Avatar
Shift just before it blows up ..
www.shazampulling.com
The older I get the less I seem to know.
TRUKPULR is offline
post #3 of 5 (permalink) Old 06-21-2012, 09:26 PM
i would start at 5400 rpms or a little lower
Drag week quickest street rod
2009 2010
quick 52 is offline
post #4 of 5 (permalink) Old 06-21-2012, 10:54 PM
light
About same set up more gear 456,950hp -victor int. loves 6000 shift pt...Bill
bigblockfairlane is offline
post #5 of 5 (permalink) Old 06-22-2012, 05:09 PM
I'm guessing the engine hasn't been dyno'd so you're not sure of the power band. Are you running it on a drag strip or do you have access to one?
If so than you could start with the shift light at say 5,000. Make a pass down the track and establish baseline E.T. and MPH. Move the shift light up by 200 RPM and go again. See if the car gets faster. Keep bumping the shift light for each pass until the car levels off and doesn't get any faster. That's where you can set your shift light.
Greg2 is offline
