8.8 Rearend With 9" ends - 460 Ford Forum
post #1 of 4 (permalink) Old 04-29-2015, 04:37 PM Thread Starter
Question 8.8 Rearend With 9" ends
I have a set of axles I been running , that are 35 spline with c-clip elem's.... I'm wanting to press on a 9" bearing.. Moser told me they had to machine off the ring where the 9" bearing would stop , to use the clip elem's... Said I could still use my axles, but would have to press on some kind of ring for a stop... Anyone know what I could use here.... And anyone know where the 9" bearing would rest at for as measurement when pressing it on ????
colormebad is offline
post #2 of 4 (permalink) Old 04-29-2015, 05:55 PM
can I ask why are you wanting to change the C-clip eliminators???
butterbean is offline
post #3 of 4 (permalink) Old 04-29-2015, 05:59 PM
and if you are going to put 9" bearings on your axles, you will have to cut off the 8.8 axle ends and weld on 9" axle ends
post #4 of 4 (permalink) Old 04-29-2015, 08:25 PM
Mustang-Junky's Avatar
Quoted: 6 Post(s)
I believe they call that the wedding band. It's a press fit to hold the bearing on. Where it ends up depends on the distance the axle face needs to be from the housing end for your brake set up.
Jess
'90 mustang 545, Weiand tunnel ram, Predator carbs, c-4 with brake, 4800 stall UCC, 9" 4.10 gears, 390/45r 15 drag radials, ladder bars.
Mustang-Junky is offline
