38 gallon fuel tank - 460 Ford Forum
post #1 of 4 (permalink) Old 08-10-2017, 09:09 PM Thread Starter
38 gallon fuel tank
I have a 95 f250 and I can find the 38 gallon fuel tanks for up to 89 models my ? Is what modification would be need to make it work on a 95 I know the fuel pump needs to be modified for the extra deep sump but to me it looks like a direct bolt in
nelz214 is offline
post #2 of 4 (permalink) Old 12-12-2017, 10:50 AM
Quoted: 49 Post(s)
I don't know about a single 38 gallon for a '95 model, but you can get even more capacity by using a 32 gallon Bronco tank in the rear, and keeping your 18 gallon in the forward position for a total of 50 gallons. You'll still have the tank switch valve, but you'll have a lot of fuel on board. You will have to ditch the spare tire mount though.
The first 38 gallon I knew about was on the Superduty models.
Dukeofdiamonds is offline
post #3 of 4 (permalink) Old 12-13-2017, 10:55 PM
Farm's Avatar
You can fit a 38 gallon tank in the rear and the standard 18 gal in front as well. There's a real good write up on a powerstroke forum if you google the swap.
Sent from my SM-G930W8 using Tapatalk
Farm is offline
post #4 of 4 (permalink) Old 09-29-2018, 11:29 PM
460flatbed85's Avatar
It's a great upgrade!! I just finished mine eliminated the midship tank and the problematic tank switch. Probably the best upgrade i have made on my 85.
Jon 1985 6.9l diesel chassis running a (1979 7.5I 460), f250, 4x4, t19, BW1345, front: (light duty) dana 44 ifs and rear: dana 60 full floater.
3G alternator, duraspark II :-drink
460flatbed85 is offline
