10.25 RD lower gear ratio... - 460 Ford Forum
post #1 of 2 (permalink) Old 02-28-2019, 02:51 AM Thread Starter
Question 10.25 RD lower gear ratio...
here goes, I have an 87 F-250 with a 460, C6 auto trans with a 10.25 rearend 3.55-1. I'm currently using it as a second vehicle and I'd like to get the RPM's down on the highway as inexpensively as possible. I was thinking a new ring & pinion but but i cant seem to find anything lower then what I have. This may be a stupid question but is there another diff size that uses the same size ring & pinion set? thanks.
Coleman8r is offline
post #2 of 2 (permalink) Old 03-04-2019, 06:50 PM
Quoted: 11 Post(s)
As far as I know, no. 3.55ís are the highest (or lowest) you can go. You might try to find a used Gear Vendors overdrive.
78 F250, 466/C6/205, EFI, Dana 60 4.88 spool, Ford 10.25 4.88 lincoln locker, Custom 4-link rear coil springs, Custom 3-link front coil springs, 39" Boggers on 12" Weld SS's (sold)
2006 Blue/Gray F250 4x4 CC 6.0 Torqshift NP273
79 F350, 521/T18/205, Dana 60 4.10 detroit, dana 70hd 4.10 Lincoln locker, 36" Rockers on 12" Eagles.dynoed at 628hp and 685ft/lbs torque at 5000rpms all iron
lonco is offline
Ford Motorcraft E3TE-RD 4180 series carb clamb General Tech 0 03-27-2015 05:35 PM
Sterling 10.25 and 10.5 differential cover deluxetruck 4x4's, Pullers, Crawlers and other HD rides 8 09-10-2009 08:05 PM
88 F250 4x4 axles posi 4.10 Dana 50/ Sterling 10.25", KY, $400 Behemoth DT The Auction Block 4 06-23-2009 08:41 PM
Want to trade 4.10 gears for 3.73-10.25" sterling Behemoth DT The Auction Block 1 05-13-2009 05:49 PM
Rd. Const. For Support Our Troops Cruise Phila. 4/21 7DMACH1 Chilly's Garage 0 04-20-2007 08:56 PM
