12.9@111 - 460 Ford Forum
Race Talk Tech and Non Tech Discussion
post #1 of 30 (permalink) Old 12-18-2011, 09:35 PM Thread Starter
WildFire532FB's Avatar
WildFire532FB is offline
post #2 of 30 (permalink) Old 12-18-2011, 10:00 PM Thread Starter
I guess i should also add i didn't do a burn out and you can tell i am granny shifting, didn't want to break it but i spun a bearing or something anyway.
post #3 of 30 (permalink) Old 01-04-2012, 09:19 AM
hey buddy, i wish i was in town to see that. i took out my 73 mach 1 to sac a few times and ran my mild 466. i can see from the other forum you are running nitto 555r's.
with the nitto nt05r's i did a best of 13.015 and i actually did it against the owner Dave Jr. in the other lane.
with my full slicks with the skinnies up front, i got a 12.690.
i haven't gotten use to how to launch a manual shift car yet cuz it ain't quite the same than a automatic with a trans brake.
when i get back, i'll have my 521 built and i can't wait to take her out to TNT out with you at the same time.
xoliex is offline
post #4 of 30 (permalink) Old 01-04-2012, 11:23 AM
nickbay's Avatar
Quoted: 20 Post(s)
Nice car, sounds good. I'm sure you know you need slicks bad.
Speed shifting will improve ET, but not until you get traction.
http://s212.photobucket.com/albums/cc110/laveennick/
nickbay is offline
post #5 of 30 (permalink) Old 01-04-2012, 07:12 PM
at 111 mph your making hp to put u in the hi 11's. when u get slicks need the 60ft. in the mid 1.5s and the shifting down look out 11's here i come.
Drag week quickest street rod
2009 2010
quick 52 is offline
post #6 of 30 (permalink) Old 01-04-2012, 07:39 PM
Thumbs up
One you get that to hook and launch it hard, I see a mid 11 second ride.
429TORQ is offline
post #7 of 30 (permalink) Old 01-04-2012, 11:53 PM
i would hope he'd get down to a 11.0 ET!
xoliex is offline
post #8 of 30 (permalink) Old 01-05-2012, 01:35 PM
11.0 noway at 111 mph 119-120 mph and a good 60'
2009 2010
quick 52 is offline
post #9 of 30 (permalink) Old 01-05-2012, 02:44 PM
i would assume with slicks and a hard launch he'll be able to pick up some MPH. when i finally ditched the regular street tires and went to slicks and a functional ignition box. i picked up 10MPH with the same motor with nothing else done.
just my situation though, i went from 98mph at the traps and then went to 108MPH with just tires and ignition box. (had a going bad MSD 6A, and then placed a STOCK duraspark module)
xoliex is offline
post #10 of 30 (permalink) Old 01-05-2012, 11:07 PM Thread Starter
My fastest MPH for the day was 113.
I spun a rod bearing or multiple ones on the run after the one in the video which i am sure was better than 12.9
My motor is out now and i am going to rebuild it and hopefully come back stronger and faster. The heads and intake need to be ported better and i never degreed the cam.
68 Mustang Fastback 532ci
post #11 of 30 (permalink) Old 01-08-2012, 08:31 AM
since the bearings are spun on the rods, are you going to be able to have the crank welded and have all the rods reconditioned? or are you going to have to buy a completely new stroker kit?
if your buying a new kit, are you just going to go to a 557 kit?
xoliex is offline
post #12 of 30 (permalink) Old 01-08-2012, 02:10 PM Thread Starter
I hope i don't have to do anything like that and they can fix all my parts.
post #13 of 30 (permalink) Old 01-09-2012, 07:53 AM
How is the tune on the car?
111-113mph seems pretty low for 532ci and that chassis....
What trans you running?
69fb is offline
post #14 of 30 (permalink) Old 01-09-2012, 09:48 AM
any news on your engine. did watch your video and for sure u can pick more et. hope your engine turns out ok good luck
2009 2010
quick 52 is offline
post #15 of 30 (permalink) Old 01-10-2012, 09:49 PM Thread Starter
TKO600.
Tune is good, i think. Ran good and everything. It seemed at the lower elevation though it dieseled a lot not sure what would have caused that.
