header gaskets - Page 2 - 460 Ford Forum
Jon Kaase Racing Engines Jon Kaase is considered one of the best minds in the world of Big Block Fords and has created many parts to help enthusiasts with their 460 based projects. Gentlemen start your questions…
post #16 of 19 (permalink) Old 02-27-2015, 09:14 AM
gaskets
Originally Posted by HPbyGD View Post
X2 :-)
GD
flat. ! straight. ! thick flang, re torque after heat cycle.. i used the fel-pro non stick but they will anyway. put them back on the same way they came off a little WD 40 on both sides to help them seat and reuse... RTV works.!! no gasket required i just didnt like the clean up, a bit messy for me. done....
jeffery2304 is offline
post #17 of 19 (permalink) Old 02-27-2015, 09:36 AM
Bought three pair of headers in my life. Only the Thorleys were flat enough to seal. Two pair had to go to a machine shop to be flattened. Only found one local machine shop that would/could do the job. They used a large belt sander holding the headers by hand. It didn't look very precise but it got the job done.
Had a tour of an engine rebuilding shop many years ago that had a 12-14" disc sander mounted horizontally in a flat table to flatten exhaust manifolds. That looked like the right tool.
Jima is offline
post #18 of 19 (permalink) Old 02-28-2015, 07:44 AM
I run Hooker Super Comps and the gaskets they provided. 6 years later they are still sealed. Cheap headers cause leaks.
kyle102565 is offline
post #19 of 19 (permalink) Old 07-22-2015, 04:46 AM
Smile Header gaskets
I`ve always used permatex ultra copper for my header gaskets it always works perfect and seals perfect,no leaks.
460 lincoln is offline
